I was installing a 12 v receptacle. I was using butt splice connectors to Y the receptacle and the
light to the existing wire pair.
I used a multimeter to determine which wires coming through the wall were positive and negative. The
light works no matter which way it is wired. I had the receptacle wired backwards and fixed it. I plugged a voltage monitor into the receptacle and it worked.
I was using jumpers to connect the wires from the wall to the connectors for the
light and receptacle. When I crimped one of the wires from the wall into the splice connector, I evidently blew the circuit. I'm not sure how because the other wire was disconnected.
The
lights on port side work and those on starboard don't.
How do I reset the circuit? This is on a
Parkliner. I know which circuit it is in the breaker box, I just don't know how to reset it.
