How do you make turn signals work on side lights? - Fiberglass RV
Old 05-28-2014, 09:49 AM   #1
Rusty99's Avatar
Trailer: 1972 & 1978 Bolers 13ft
Hi all,
Has anyone got the know how on making the side marker lights as I call them or park light lights flash when your rear turn signals flash?
I would really like to know how to pull this little project off as I find it nice to be able to look in the side mirror and see the little side lights flashing away when I'm turning.
Advice and diagrams is greatly appreciated.
Cheers
Russ
Rusty99 is offline   Reply With Quote
Old 05-28-2014, 10:30 AM   #2
Trailer: Fiber Stream
Lightbulb You need a converter and...
I did it using a second set of side marker lights and a converter. I used a second set of side marker lights because I didn't know how I could wire up a fixture with only a 1 filament bulb to do 2 different functions.
Adding a Third Brake Light to Trailer | etrailer.com
Vehicle to Vehicle Taillight Converter Part #118158
The 1st link talks about a 3rd brake light output, which I discovered has to be connected to a lamp fixture to make the turn signal outputs (that the link has capped off) work. I did not care about adding a 3rd brake light to the back of my trailer, so I just connected it to a light hidden inside a compartment. I connected the yellow (left) and green (right) outputs to the second set of side marker lights mounted above the regular side marker lights.
Old 05-28-2014, 10:40 AM   #3
Rusty99's Avatar
Great Info! Thanks! I will tinker around in the garage this afternoon and I'm sure I will have more questions for you, lol.
Cheers!
Old 05-28-2014, 12:11 PM   #4
Trailer: Helite
I installed additional LED lights that I purchased at Walmart on both sides of the camper and they are wired to the turn signals. Walmart has some for less than $10 in yellow or red.
Art VanDelay is offline   Reply With Quote
Old 05-28-2014, 06:30 PM   #5
Rusty99's Avatar
I seem to have done something wrong when I wired up my new LED tail lights. I get no lights at all? Any suggestions on how to trouble shoot? My old lights worked fine.
Does the white ground wire coming out of the trailer have to be connected to metal on the trailer? I connected to white wire coming from the Boler directly the the white wire on the LED lights. Perhaps this is my trouble?
Old 05-28-2014, 07:26 PM   #6
Art, do those extra lights also come on with the stop lights?
Old 05-28-2014, 08:10 PM   #7
Russ, you are trying to wire a motor vehicle light to an RV light. The white wire is ground for the trailer and black in the light.
Old 05-28-2014, 10:50 PM   #8
FTTRV's Avatar
Trailer: tp
LED Tail lights
White wire on light is ground, black is stop, red is turn.
chuck
Old 05-28-2014, 11:31 PM   #9
Night Sailor's Avatar
Connecticut
Ground wire is white. Typically at the trailer tongue it is bolted or riveted to the trailer frame. The other lights white eire must each be grounded to the frame.
Alternatively all the white wires can be bonded together with wire. More work, a bit more wire so that adds weight and time to install.
If your lights are not working, the typical problem is the ground.
Old 05-28-2014, 11:38 PM   #10
Rusty99's Avatar
Ok, so I'm a bit confused still.
From the picture I've posted. I have White - White wire, Green (boler) - Black (light) and Brown (boler) - Red (light). From the replies so far, I'm not sure I'm understanding my where I went wrong. Sorry folks but can you let me know if the wires I've connected together are done correctly.
Thanks again
Russ
Old 05-29-2014, 12:25 AM   #11
Connecticut
Trailer wiring harness :
Yellow is left turn,
green is right turn ,
Brown is running lights,
White is ground.
For tail light assemblies
Black is running lights
Red are turn signal indicators
White is ground.
All other lights are wired to the brown on the trailer harness (running lights)
Old 05-29-2014, 12:27 AM   #12
Connecticut
If you want side lights to flash like signal lights wire separate lights to the red on the appropriate sides, which will also be yellow on the left and green on the right of the trailer harness.
Old 05-29-2014, 05:34 AM   #13
Some lights, mainly the foreign made ones , I have found do not use the standard color code. Just recently wired some up that used red as tail light and black as turn !!
Old 05-29-2014, 01:10 PM   #14
Trailer: Aliner folding & Weekend Warrior toy hauler
Ohio
Hi all,
Has anyone got the know how on making the side marker lights as I call them or park light lights flash when your rear turn signals flash....
It is really easy to do by relocating a couple of wires. Rather than me explain it, read here;
Daniel Stern Lighting Consultancy and Supply
I haven't tried it on a trailer when pulling with a TV that uses a light converter box. It may interfere with the electronics in some way.
Shopping for a fiberglass TT
Currently own;
2009 Pontiac Vibe pulling a 2009 Aliner Sport = 22 MPG
1998 Ford E150 pulling a 2006 Weekend Warrior toy hauler = 8 MPG
beemerphile1 is offline   Reply With Quote
light, lights
Best ways to pickup and boost free WiFi signals while in motorhome? magentawave Problem Solving | Owners Helping Owners 9 11-16-2013 10:18 AM
LED Turn/Stop/Tail Lights FTTRV Commercial Posts and Products 1 03-03-2013 08:31 PM
Brake Lights, Turn signal lights, marker lights, oh my! glamourpets Problem Solving | Owners Helping Owners 19 01-03-2013 10:10 AM
Brake/Turn Signal Lights Red-Dwarf Problem Solving | Owners Helping Owners 7 05-15-2012 09:54 PM
Using side marker lights as turn signals al gilliland Care and Feeding of Molded Fiberglass Trailers 30 08-14-2009 04:53 PM
