How long will a battery last? - Page 3 - Fiberglass RV
Old 06-15-2016, 04:52 AM   #41
Raz
Raz's Avatar
Voltage is always measured across. I recommend a digital multimeter (DMM). Avoid anything with an analog readout. It's likely to have a lower input impedance which could effect the accuracy. A $15-$20 meter is fine and can be purchased in most hardware or auto stores. You want one with its own battery. Meters that draw there power from what they are measuring can effect the measurement and can cause parasitic drain if left plugged in. Raz
Old 06-15-2016, 05:52 AM   #42
Originally Posted by Bluetang99 View Post
Quick question for you electrical experts. If I want to install a voltmeter can I splice it into any 12v circuit or does it have to be installed between the battery and pd4045 fuse panel?
Overly simplified, the further you get from battery the more the voltage that you measure will be less than the true battery voltage, but the amount will almost certainly be trivial. This is especially true when you consider the inaccuracy of using voltage to measure the state of battery charge in the real world.
Recent battery charging, discharging, and temperature all effect the reading you get and must be taken into account to get the best idea of the battery's state of charge based on voltage. These factors will have more effect than where you measure the voltage in a typical FG trailer. It is best to let the battery sit for a few hours while disconnected before taking a reading. Take a few minutes to read The 12volt Side of Life (Part 1) (esp. the "Testing your batteries" section).
Old 06-15-2016, 06:04 AM   #43
Originally Posted by Raz View Post
..I recommend a digital multimeter (DMM). Avoid anything with an analog readout. It's likely to have a lower input impedance which could effect the accuracy. A $15-$20 meter is fine and can be purchased in most hardware or auto stores. You want one with its own battery. Meters that draw there power from what they are measuring can effect the measurement and can cause parasitic drain if left plugged in. Raz
To give you an idea of just one of the challenges of using a voltmeter to figure out how much charge is left in your flooded battery, I bought two meters with digital displays and both read about .10 volts different from my quality digital multi-meter. Now, .10 volts but not sound like much but according to Mark S. Nemeth (The 12 Volt Side of Life guy), there is only a .21 volt difference between a battery that is 75 % charged and one that is 50% charged (and ideally should not be discharged any further). So being off by only .10 volts could easily give you and inaccuracy of 12% or more.
Old 06-15-2016, 06:33 AM   #44
Raz
Raz's Avatar
As I said once before. I used to take 5 bench quality meters and connect them to the same source. All would read different. In the lab our tech would use a very expensive temperature compensated voltage standard (sent out yearly) to calibrate meters. Still the meters will read different.
Calculate you usage. Choose a battery to meet that demand. Use your meter to check on things once in a while. Get used to "close enough".
Old 06-15-2016, 09:56 AM   #45
New Jersey
A better quality multimeter is something I will need to invest in then. Right now all I have is one of those big harbor freight meters that they give away free with any purchase and one of the prongs already fell off.
Bluetang99 is offline   Reply With Quote
Old 06-15-2016, 11:16 AM   #46
"approximately correct"....
or "close enough" by another name.....
I don't think no one will ever know exactly how much power is in their "tank"... and as somebody said the nature of the numbers means that a small change in them means a large amount...12.6+ to 12.2 doesn't sound like much but it is 100% of the power at your disposal (below 12.2 you are not being "nice" to your battery and will pay for it later)
I got tired of taking out a meter every time...so I installed a permanent one...and I really like having it.....it gives me good info like how fast I'm using up available power....as a for instance: when the furnace (biggest power hog in our trailers) kicks in the displayed voltage drops like a rock into the elevens...when it shuts off the meter climbs back up to within one or two hundreds of a volt from where it was before...this sort of tells me that if I run the heater all night (10-12 cycles) I will spend .2 volts during the night...again doesn't sound like much but that is HALF of available power IF my battery was right FULL when I started.....
a hydrometer reading of a battery at rest for an hour is probably the best measure....but nobody wants to do that every day/night...
as said before...there's a lot of close enough, sort of, gut feel and approximately in this business...good voltage info will make you comfortable and less susceptible to "power anxiety" fully using your trailer unplugged.....just my opinion of course
Old 06-15-2016, 11:31 AM   #47
New Jersey
I was also looking at those meters but from what I saw is that they all come with bright blue displays that are on all the time and i just wasn't sure of how much battery it would eat just running a meter like that and also if it would be too bright in a scamp 13.
Another issue I ran into was they all seem to ship from China and I don't have time to wait around until July or August because of their slow shipping.
Old 06-15-2016, 12:10 PM   #48
I already have a few of these from China.. New Auto LED Cigarette Lighter Voltage Digital Panel Meter Voltmeter Monitor Car | eBay
Just plug it into your cigarette lighter socket when you want to get a reading. If you don't have such a socket, maybe add one.. they are very handy.
If you want to PayPal me $8 you can get one in a few days (CONUS only).
Its off about .1 volts at 13 volts.. but like everyone says, that is close enough.
Of course you can add a switch to any panel type always on meter too.. I use a momentary contact one, so it works only while the button is pressed.
Old 06-15-2016, 12:42 PM   #49
New Jersey
That's a cool gadget, I was wondering if they made those. I do have two of those sockets wired up in my Scamp so I will probably buy one from you. Just give me a few days and i will pm you for your PayPal info, I just have to take care of a few other items for my camper first. Thanks.
Old 06-15-2016, 01:00 PM   #50
on all the time....
that's what the switch below it is for....to turn it off...
about the cig. plug meter mentioned....before this panel meter I had another one that was three digits (like the cig. plug model)...unfortunately I did not feel like it gave me enough information....about as much information as if your fuel gauge in your car only told you if your tank was full, half full or empty.....(I reused the three digit meter for voltage from solar panels) four digits way more useful IMO
shipping for the 4 digit was a couple of weeks IIRC
Old 06-15-2016, 01:03 PM   #51
New Jersey
How do you have it wired, right to the battery or somewhere in between?
Old 06-15-2016, 01:06 PM   #52
and about the pic....
IIRC the picture was taken with charger off....voltage from panels reads 16.6....the batteries appear full as the solar charge controller is supplying 13.3 volts to the system (maintenance charge)
Old 06-15-2016, 01:11 PM   #53
New Jersey
I will look into both types of voltmeters more closely, realistically I only need it to tell me when the battery is half full, if it even gets to that point.
We went camping for two days and when I checked my battery it read 12.4 after using everything besides the TV. I would say the longest I would dry camp would be 3 days.
I will have to test again after I get a 12v fan and media player for the TV.
Old 06-15-2016, 01:15 PM   #54
close to the battery....
it's wired to a circuit I ran to/for my "home made dash panel thing"... fused 10A...from the battery cut-off switch
the 15A fuse is on the solar panels circuit
Old 06-15-2016, 01:23 PM   #55
Raz
Raz's Avatar
And then there is loading.
Go to your car. Turn on the lights. Now start the car. The lights dim because the battery voltage drops due to the large current drain of the starter motor. That's called loading. Any time you draw current, the source voltage drops only to raise again when the current is turned off. The more current, the greater the drop. The ability to maintain a constant voltage over a range of current is called regulation. Electronic power supplies, (AC to DC converters ) are designed for good regulation. Batteries don't have very good regulation. So when using your meter to check the state of charge of your battery it's not just the variation in meter readings that can cloud things. Loading can too.
And then there's noise....
Old 06-15-2016, 05:16 PM   #56
Trailer: 2013Escape 21
Iowa
Those 12 volt coolers will drain your camper battery or you tow vehicle battery like a big hog on corn at a trough. My brother offered me one and I said no thanks. I like a good reasonably priced cooler and don't mind a little ice bill. If you're only out for three days make good hard ice at home and most any "5 day" cooler will get you by. Especially if you precool your drinks in your home refrigerator. Having a cooler drained battery is not good. Spoiled food, nothing else will run and worst of all warm beer. The ice company's kids need shoes too.
Dave
Iowa Dave is offline   Reply With Quote
Old 06-15-2016, 05:46 PM   #57
New Jersey
Dave
That's the conclusion we came to after camping this week. We used $4 in ice for almost 3 days and even having the cooler sit outside overnight the ice still wasn't melted and everything was nice and cold.
Old 06-15-2016, 06:00 PM   #58
...like a big hog on corn at a trough. ...
You really are IOWA Dave, aren't you
OP was only running lights and a TV. No fridge or cooler.
I think he has the info he needed so..
Speaking of coolers... does anyone use dry ice?
Old 06-15-2016, 08:08 PM   #59
anything...
anything's possible...
I cruised for several years on an 18 foot sailboat....these trips consisted of three nights, four day outings.....
night before launch do a grocery shop...put all the meat in a bag and ask the clerk to put it in their freezer overnight...pick up in morning (common request around sailing/marina areas)....
one block of ice, frozen meat....that smallish cooler was one large block of ice starting out...one AGM battery ran the boom box, tiller pilot and a cabin light for the four days with no problem....
great trips...."the smaller the boat, the more it gets used...the more interesting places it gets to"....
if my big fridge ever quits I might just build a real good ice box, in it's place, in my trailer...
battery
How long will battery last... NedMac Electrical | Charging, Systems, Solar and Generators 43 07-27-2015 08:47 PM
how long does this propane tank last? john warren General Chat 13 08-30-2012 12:58 PM
How long does a 5 gallon propane tank last? Perry J Problem Solving | Owners Helping Owners 6 09-20-2010 03:22 PM
'09s last hou-rah (last one at The Fort) Doug Mager Ft. Langley B.C. Rallies 5 10-18-2009 10:21 AM
How long can it last? Lainey General Chat 5 11-03-2008 03:28 AM
