How long will battery last... - Page 4 - Fiberglass RV
Old 07-27-2015, 04:11 PM   #43
rdickens's Avatar
Trailer: 2017 Scamp 16 Deluxe
Dawn,
Yes.
Other than picking the size of the panel, the actual connections are really very simple.
I used 2 wire nuts to make the connections from the solar panel to the controller (you may need to remove a little more isolation from the red and black panel wires in order to twist the copper together before twisting on the wire nut).
Then, I used 2 wing nuts to attach the ring connectors on the battery end of the controller to the threaded battery posts.
The instructions in the controller are fairly clear.
Note that all panel's rated wattage are for optimum directional conditions in full sun. I think that the crystalline panels may do a little better in suboptimal conditions than amorphous panels that require larger size panels. Someone else may comment on that.
The 35 watt panel will provide slightly less than 3 amps in full sun. That is slightly more than the 2 amp low setting of my home car charger.
With my limited current usage, all I really needed was the .7 amps provided by my 12 watt panel.
As Floyd said, a group 27 battery will last a while on its own. If you are even trickle charging, you will extend that even farther. If you are trying to run microwave ovens and flat screen TVS, you would probably need multiple batteries and multiple larger wattage panels.
As I said, YMMV. 😉
Good luck! ☺
Ray
Sent from my SCH-I545 using Fiberglass RV mobile app
rdickens is offline   Reply With Quote
Old 07-27-2015, 08:47 PM   #44
rdickens's Avatar
BTW - The Northern Tool 35 watt crystalline panel should still fit on our gravel shield.
(My wife and I both thought that we might "get by" with the 12 watt panel and it was more "Scamp13 size". It did do the job for us during our 8 days of dry camping ... perhaps just barely?)
After looking at the 35 watt panel specs, it generates just over 2 amps.
If I was powering a furnace, I would probably choose the 35 watt panel. I don't often dry camp and I think that about $150 is all I would really want to spend for maintaining the battery with our minimal current usage. (Quieter, lighter, and much cheaper than a $600 to $1000 generator. And, no need to carry gasoline or go out and buy more gas. 😉 )
With the 54" bed and the weight restriction (1500 lbs) of our tow vehicle, I did not have a furnace installed. I wanted the full height door under the sink (the furnace would have taken half of that precious storage space.)
We rarely camp in super cold weather, so we just use a small space heater and/or our warm sleeping bags.
Again .... Good luck with whatever you decide is right for your situation! ☺
Ray
battery, scamp
12VDC/120 VAC Flat Screen on WOOT.COM - Won't Last Long..... Bob Miller Problem Solving | Owners Helping Owners 0 09-24-2012 08:44 AM
how long does this propane tank last? john warren General Chat 13 08-30-2012 12:58 PM
How long does a 5 gallon propane tank last? Perry J Problem Solving | Owners Helping Owners 6 09-20-2010 03:22 PM
'09s last hou-rah (last one at The Fort) Doug Mager Ft. Langley B.C. Rallies 5 10-18-2009 10:21 AM
How long can it last? Lainey General Chat 5 11-03-2008 02:28 AM
