How often do YOU check battery with hygrometer - Page 2 - Fiberglass RV
Old 11-11-2017, 12:57 PM   #15
If I pull my battery to check water levels, the hard part is done. So why not check with hygrometer. For my next battery (years away I hope) I plan to skip AGM and jump to Lithium (2x capacity, 1/2 weight).
pete_britt is offline   Reply With Quote
Old 11-11-2017, 12:59 PM   #16
widgetwizard's Avatar
Some of us dont have to "pull" our batteries to check water levels....
Retired from Orbital Machine Works.
Where is Jim now? Here.
widgetwizard is online now   Reply With Quote
Old 11-11-2017, 08:00 PM   #17
Hmmm again I have to ask how often do you check the water level of the battery in daily drive?
Byron Kinnaman is online now   Reply With Quote
Old 11-11-2017, 08:04 PM   #18
I tend to check mine each time the topic comes up on the forum.
Old 11-11-2017, 08:15 PM   #19
I've been known to do that. However, I only added water to one battery once. I'm on battery # 4 on 12 years. Fist one I missed diagnosed the problem and replaced it when I didn't need too. The second one stopped holding a charge. The 3rd somebody else wanted it worse than I did apparently, and the 4th is still in use. And wouldn't you know it the 3rd was the most expensive true deep cycle battery. Went back to a marine hybrid at 1/2 the cost.
Old 11-11-2017, 09:06 PM   #20
maybe a suggestion
here is a thought I have done this to keep from boiling out a battery put a timer on your el. line!
bob
Old 11-11-2017, 09:09 PM   #21
bob
My trailer has been plugged in for 9 years. What time should I set the time for?
Old 11-11-2017, 09:47 PM   #22
rbryan's Avatar
Trailer: 2015 Escape 19 "Past Tents" 2015 F150 Lariat 2.7L EB SuperCrew
They definitely have their selling points, such as thousands of cycles and no issues with 100% discharge. But at over 2 grand for one with decent Ah, let's hope the years ahead see them drop in price. Just not practical at their current prices.
rbryan is online now   Reply With Quote
Old 11-12-2017, 06:34 AM   #23
sot of
well glenn I suppose the time duration would be up to you. I think a few hours a day charging when nothing is running in the trailer would be more than adequate but I don't know much!
bob
Old 11-12-2017, 10:56 AM   #24
Virginia
Once a year.
Neto is offline   Reply With Quote
Old 11-14-2017, 03:19 PM   #25
Buggeee's Avatar
Trailer: Playpac
OH
Originally Posted by John Linck View Post
. The sun shines most days and the battery is bathed in the sun's fusion powered raditation photon goodness.
Toymaker and Wordsmith.
Thank you for the smile John.
Buggeee is offline   Reply With Quote
Old 11-14-2017, 07:02 PM   #26
jon carpenter's Avatar
Trailer: 2012 Casita 17' SD
Illinois
Thanks for all of the responses. It sounds like the general consensus is seldom or never for a lead acid battery and never for an AGM obviously . Sounds like I am over checking at several times a year. Guess I am a worry wart. Perhaps I will keep the hydrometer just in case.
thanks....jon
jon carpenter is offline   Reply With Quote
battery
Battery Hydrometer Darwin Maring Electrical | Charging, Systems, Solar and Generators 2 10-18-2013 04:13 PM
wildness is unpredictable, often with tragic consequences Penney H. & Mike E. General Chat 40 01-09-2011 10:02 AM
How often to backflush? joelh Care and Feeding of Molded Fiberglass Trailers 7 11-02-2010 05:57 PM
How often do leaf springs fail? TonyB Towing, Hitching, Axles and Running Gear 11 01-11-2008 08:40 PM
I've often said... Doug Mager General Chat 1 12-18-2006 07:36 AM
