In line charger query - Fiberglass RV
Old 09-10-2012, 01:47 PM   #1
Sue and Henry's Avatar
Name: Sue and Greg
Trailer: 1982 Burro 13 foot and a 2015 Casita Spitit Deluxe 17 ft.
I purchased a charger for my battery from napa, but have not used it and want to exchange it for an in line charger that will automatically charge when I park and plug it into 110.
This is what I bought:
And I think what I'll need is maybe one of these:
If I understand the process, it fits under the front bench of the burro and hooks into the electrical there. Is one of these what I need?
Sue and Henry is offline   Reply With Quote
Old 09-10-2012, 02:15 PM   #2
Trailer: Bigfoot 2500 truck camper
That is a battery isolator used to allow your tow vehicle to charge more than one battery with its engine alternator. It does not hook up to 110 VAC. You should get an intelligent or smart charger with 3 or 4 stage charging. You can can leave them hooked up to the battery without worring about overcharging. I use a model 3300 from this company.
CTEK Battery Chargers | The World's Smarter Battery Charger
Rene is offline   Reply With Quote
Old 09-10-2012, 02:28 PM   #3
Before I bought a new power converter that has the smart charger in it, I wired a flush mount 4 prong plug to the battery, using two of the terminals, one for positive, one for negative. I mounted it on the end of a seating area. The other end of the plug I put two short leads to match the plus & negative of the mounted one. When the battery needed charging I would plug in the leads and hook a regular auto battery charger to them. The charger gauge will show when the battery is charged. This is a much cheaper solution than a converter/ charger, mine was $170. I would think one of the battery tender chargers would work good, they are designed to keep batterys charged in cars that are in storage.
Old 09-10-2012, 03:05 PM   #4
Name: Sue and Greg
Thank you so much - both of you - you've saved me from another mistake.
Old 09-10-2012, 03:41 PM   #5
David Tilston's Avatar
You might want to take a look at this thread:
Trillium 4500 replacement converter?
The original poster put it in a Trillium 4500, but it would work in any trailer. He paid about $200 for it.
Old 09-11-2012, 02:14 PM   #6
Name: Sue and Greg
Thanks David. It appears I need to either learn the language and electrical concepts or find a shop I can trust. This looks like it is going to be over my head. Know of someplace in the LA area that will find the least expensive way to get my 82 Burro battery charged when I'm plugged into 110?
Old 09-11-2012, 02:59 PM   #7
Thomas G.'s Avatar
Trailer: For Sale Or Rent
Rooms to Let 50 Cents
Sue, don't give up so easily. Worst case, you can just buy a smart charger made for cars and clip it to the battery terminals and plug it in. But installing a converter is only a little harder and you can do it with our help.
A smart charger that you just clip on and plug in:
Schumacher SE-70MA Fully Automatic Deep-Cycle Charger : Amazon.com : Automotive
Old 09-11-2012, 08:10 PM   #8
Name: Sue and Greg
That sounds hopeful Thomas. I'm going to the lake casitas rally in October. Maybe there will be an old fiberglass like mine - if I can see the setup.
Old 09-12-2012, 04:51 AM   #9
Thomas G.'s Avatar
I think that you will be surprised at how easy it is once you understand how it works.
Query about door lock to lock from inside sara maccalman Problem Solving | Owners Helping Owners 4 11-14-2010 06:11 AM
painted the 69 charger way steve J Problem Solving | Owners Helping Owners 4 10-19-2009 05:25 PM
Trillium 4500 Frame Repair Query gouldmorrison Problem Solving | Owners Helping Owners 4 12-06-2007 02:05 PM
trickle charger Ericpa3 Problem Solving | Owners Helping Owners 8 10-30-2007 05:57 AM
