Inside side lights - Fiberglass RV
Old 06-30-2015, 07:58 AM   #1
Trailer: 1974 13' Boler
Inside side lights
Hi there, the inside side lights on my 1974 boler have been cut and I want to hook them up so they run off the 110 power when i plug into shore power. How do I do this and what size wire would I need to extend the cut wires? Thanks
Ronise99 is offline   Reply With Quote
Old 06-30-2015, 11:40 AM   #2
Roger C H's Avatar
Talking Electrical
Hire an electrician. If you are going to have 120vac running in your rig, you need a GFI (Ground Fault Interrupter) so you don't electrocute yourself.
FYI We changed our 12vdc incandescent for LEDs just because of the heat generated by the bulbs. I think 120vac lights would generate lots of heat.
light, lights
Brake Lights, Turn signal lights, marker lights, oh my! glamourpets Problem Solving | Owners Helping Owners 19 01-03-2013 10:10 AM
Solar lights inside itlives General Chat 14 02-01-2012 09:34 PM
HELP!! No inside lights!! Christi W Problem Solving | Owners Helping Owners 12 01-27-2007 07:27 PM
LED Inside Lights Darwin Maring Care and Feeding of Molded Fiberglass Trailers 3 11-09-2006 06:57 PM
LED Reverse lights - inside trailer ? Kurt in BC Modifications, Alterations and Updates 3 04-18-2006 04:09 PM
