Interior LED Lighting - Page 3 - Fiberglass RV
Old 09-13-2013, 06:07 AM   #29
Trailer: asdf
Alabama
Thanks peter.
jwcolby54 is offline   Reply With Quote
Old 09-13-2013, 10:47 AM   #30
Trailer: Burro
Massachusetts
For use in our 13' Burro (lots of reflective white FG) we have found that LED strips work great for reflective area lighting. I put a strip over the kitchen counter, with an aluminum "L" strip shielding it from shining directly out. This way there is no direct light in the eyes. It provides very bright soft light over the sink and stove area. If fact, it was so bright that I had to put a dimmer on it to tone it down. The strips are easy to work with as you can cut them with scissors at marked positions about every inch or so, to make custom lengths. You can then clip or solder wire leads (18 ga.speaker wire is great for this) and install the strip wherever you like.
When you are shopping for strips, know that the 5050 LED's are much brighter than the 3035 LED's and cost more, but not that much. These strips are so bright that I put 1 ft over the sink and another 1 ft over the sink and it was still too bright for casual use and needs dimming. Always use PWM dimmers and not the cheap ones designed for hot lights.
For reading lights over the bed and over the front dinette, I installed a simple 3 LED puck which also had to be dimmed down. This is easy to do in a Burro because of the double wall in which the wires can be run.
I find using LED designed fixtures much easier than converting existing hot light fixtures.
And of course all are Warm White. "Normal" white is too blue and harsh.
Regards, Rick
rick.a is offline   Reply With Quote
Old 05-10-2015, 06:19 PM   #31
Trailer: 1985 BigFoot G
Mississippi
Originally Posted by steve dunham View Post
What's CHEAP? LED trailer lights has some nice LED replacement lamps with the B15 base , just swap the lamps and your done . 315 lumens ,warm white color with voltage regulation. I used them in my Scamp and they worked great,well built & NO LED failures in 3 years. Plus they come with a guarantee
Yes there are less expensive lamps on the market!!
Eliminating the heat from the incandescent lamps was as much of a factor as power savings as a reason to change to LED lamps IMHO
Steve my camper is a 1985 bigfoot double axle and I was wondering which ones to get for it. I wanted to replace all the inside ones and the outside. I was looking today but have no clue which ones. I'll need the whole light kits on the outside except for the bottom tail lights. They all need to be replaced and I think they call them clearance lights right? The yellow front ones and the red back ones?
Gardnpondr is offline   Reply With Quote
Old 05-10-2015, 06:25 PM   #32
Mississippi
If you check your local RV supply store they may have them. More and more are carrying them but they run in the $18 per bulb range.
Cant comment on the cheaper made in China ones as to how long they may or may not last as I have not used them.
Another popular website that a lot of people here have used is Superbrightleds.com
From my experience using replacement bulbs the higher the luminus rating the better & the ones with the square flat area work much better than the cylinder shaped ones.
White vs Warm White - which ever way you go just get the same in all light fixtures.
When going to LED some people have found they need to switch the wiring on the lamp fixture otherwise the LED's dont work. Only had one fixture I had to do that on, otherwise its a pretty simple update. If you camp off the grid at all like I do you will be happy with the change well worth the money - *far* less power consumption.
Was this on the inside you had to switch the wiring Carol? Do you mind telling how you switched it? Is it the size of the wire or what?
Old 05-10-2015, 06:34 PM   #33
Mississippi
Originally Posted by rick.a View Post
If you are happy with the placement and style of the existing light fixtures that you have, then replace the bulbs as you have been considering. But adding LED lights to your interior is the perfect time to put fixtures where you really need them. In our 13' 1984 Burro, we added LED fixtures to illuminate the front dinette area (formerly a bunk) and the rear bed area. The small puck fixtures are relatively inexpensive and can be put on dimmers. If you are handy you can figure out how to run the small 12V wires to where you need them.
We also put a flexible light strip composed of a line of LED's over the sink-stove area, also on a dimmer. This was a terrific upgrade from the stock light which was a fluorescent tube shining in your face. The strips can be cut at about every 2 inches allowing you to make exact custom lengths. If you are cheap like me you also don't need the special clip on connectors. Just solder on 18 ga wires with a $4 Radio Shack soldering iron.
Parts came from:
Elemental LED
Superbright LED
Kick lighting.
If you use dimmers be sure to get PWM style (pulse width modulation) as standard dimmers for incandescent will not work. But don't get the cheap $5 dimmers from china. They will not handle the vibration in a trailer and may fail.
Most folks agree that you should get warm white LED's and not "white" as the plain white are too blue and not pleasing.
As for replacing the lamps in the existing fixtures, you get more bang for the buck by changing the cheap socket fixture in your light for a bayonette style mount which will enable you to use the flat cluster lamp style which typically are brighter behind the diffuser in your fixture.
Good luck,
Rick
I'm sure there are some video's online I could watch to see HOW this is done right? (on changing out the socket fixture)
lighting
LED Lighting ??? Randy Bishop General Chat 11 05-24-2012 05:39 PM
Interior LED lighting Video kevin61 Modifications, Alterations and Updates 8 01-03-2009 01:09 PM
New Interior lighting led light strips jimtesla Modifications, Alterations and Updates 2 09-15-2006 08:42 AM
Led lighting JIMZ Problem Solving | Owners Helping Owners 48 01-19-2006 06:31 PM
LED lighting Legacy Posts Modifications, Alterations and Updates 50 07-22-2003 10:25 PM
