Inverter & coffee maker - Fiberglass RV
Old 11-03-2017, 02:10 PM   #1
Trailer: Hunter Compact II
Being electrically-challenged but needing a pot of coffee when in remote spots with my Hunter Compact II, I'm wondering if there's a way to use a small inverter to electrify the coffee maker long enough to brew 4 cups and then unplug? All I could find were very expensive and heavy inverters and then too low wattage ones that plug into dashboard, etc. (Hope this ain't too dumb a question; couldn't find a thread that addressed this situation exactly.)
rodjones is offline   Reply With Quote
Old 11-03-2017, 02:17 PM   #2
mszabo's Avatar
Trailer: 1986 Bigfoot FT20
Takes a lot of watts to run a coffee pot. A large inverter and a couple of 6v batteries.
Then you will need to recharge then.
Find a percolating coffee pot.
I’ve done it your way. Doesn’t work well, good luck.
Old 11-03-2017, 02:19 PM   #3
I'm sure you'll hear from Jon, who successfully makes coffee and toast, using an inverter.
But, you need to do all the electrical calculations.
I bought a one-cup coffee maker from Starbucks on sale. It plugged into my 100 watt inverter, which plugged into the cigarette lighter in my company car. I made one cup of hot water to clean the appliance. Second cup of water melted the plug in the cigarette lighter.
No wonder the coffee maker was on sale. Label on it claimed 25 watts.
Old 11-03-2017, 02:21 PM   #4
DeBreez's Avatar
Trailer: 2015 Casita 17SD
Miami, FL
You need to know how much power the coffee maker draws, and then buy an inverter and cables that will handle the load, plus a little extra. The little plug-in inverters aren't sufficient.
Assuming you have a stove, you could just boil water for a french press or aeropress. We have a vintage 6-cup aluminum percolator I found at a garage sale for $3 that works great.
"...I keep blowin' down the road."
2015 Casita 17' Spirit Deluxe
2002 Toyota Tundra V8
DeBreez is offline   Reply With Quote
Old 11-03-2017, 02:36 PM   #5
Jim Bennett's Avatar
Trailer: 2017 Escape 5.0 TA
AreoPress
French Press
Pour Over
Percolator
Cowboy Coffee
Some ways to make coffee without 120V AC, and it tastes better than what most electric pots make. Most electric pots do not heat water enough to properly extract from the grounds.
Otherwise you have to have an inverter that is larger than whatever the draw of your electric coffee maker is.
2017 Escape 5.0 TA
2009 Escape 19 (previous)
Old 11-03-2017, 02:37 PM   #6
Good advice all
Thanks. A good "jolt" with guidance. Back to the old system of plain old boiling the pot!
Old 11-03-2017, 02:38 PM   #7
Alex Adams's Avatar
Trailer: 1979 Boler B1300
New Hampshire
At home I use a French Press but when I camp the old school(no filter) percolator coffee tastes better to me!
Old 11-03-2017, 02:55 PM   #8
https://www.rei.com/product/884331/g...press-30-fl-oz
This is what we use. Just heat water.
Old 11-03-2017, 02:57 PM   #9
Anything that requires heating is probably not a good idea to try with 12 DC. To me that's good rule to remember.
Old 11-03-2017, 03:01 PM   #10
alex how do you operate your French press?
bob
Old 11-03-2017, 03:13 PM   #11
Alex Adams's Avatar
New Hampshire
Bob, I put 4 heaping scoops of coffee(free scoop from Gevalia). I then pour in water that has just boiled but is no longer, making sure the mixed coffee and water doesn't go beyond the level of the pour spout on the press. I then wait 11 minutes before carefully putting the plunger part in and plunging it down to the bottom. I immediately pour the coffee into a thermal carafe because if you leave it in the press for too long it starts to get bitter. My French Press is made of Borosilicate glass which is another reason I don't take it camping.
Old 11-04-2017, 09:18 AM   #12
Trailer: 2005 17' Casita LD
I went with a stovetop percolator which I now use at home also. No battery used and good, hot coffee!
MlDierbeck is offline   Reply With Quote
Old 11-04-2017, 09:25 AM   #13
Trailer: '79 Boler 1700
Manitoba
Smile
My husband and I used a french press sometime ago and then our daughter-in-law gave us a Coleman propane drip coffee maker that they inherited, but never used. We love it. No need for electricity or an inverter. Just a small tank of propane goes a long way and we get a full 8 - 10 cups of hot coffee. It's what we use all the time when we don't have power. We never go camping without it.
CA Douglas is offline   Reply With Quote
Old 11-04-2017, 09:42 AM   #14
I use a Melita filter. You can get one cup size or larger filter holder. Simple. I heat water in my tea pot pour it in the filter filled with ground coffee which sits on the cup.
Marjy is offline   Reply With Quote
Portable ice maker Ricky 4 General Chat 2 11-25-2013 09:53 AM
S'more Maker for grills carlkeigley General Chat 4 08-11-2013 01:43 PM
Propane Coffee Maker Nancy A. Modifications, Alterations and Updates 29 10-12-2010 08:48 PM
Coffee Maker discussion Sheryl M Problem Solving | Owners Helping Owners 37 10-05-2007 01:26 PM
