Inverter Vs Converter - Page 2 - Fiberglass RV
Old 07-15-2016, 06:54 AM   #15
Thanks for the reply. I do have a typical 30 Amp marine connector on the side of the trailer which I wired directly to the Converter. Also a 30 foot cord with appropriate terminations on each end to plug into the trailer and a 30 amp pole power supply. TheTrailer came with a couple adapters one of which is from the 30 to just a typical 110 which I have been using to keep things charged etc in the drive way.
I run the lights and the small a/c unit like this and it seems to have no problem. I am hoping the generator will be able to take the place of the household current No microwave or other high draw equipment on board. Lights are 12 volt running through the convector board so my lcurrent demand should be minimal.
Thanks for all the info it is what I wanted to hear.Thank you
BonesD is offline   Reply With Quote
Old 07-15-2016, 10:07 AM   #16
MCDenny's Avatar
Trailer: Lil Snoozy
The eu2000 can put out about the same power as a common15 amp 120v wall socket. Your trailer electronics won't know the difference.
You will though, with all that racket!
Denny Wolfe
Wanderingourway.wordpress.com
MCDenny is offline   Reply With Quote
Old 07-15-2016, 11:04 AM   #17
That is great news. Every now and then things go well Happy happy
Thanks
Electric System - Converter/Inverter Specs Celeste Care and Feeding of Molded Fiberglass Trailers 5 05-06-2012 07:39 AM
Trying to figure of Inverter/Converter, etc. Vickie B. Problem Solving | Owners Helping Owners 22 10-26-2010 01:27 PM
Inverter or Converter That is the question Johnathan Gallant Modifications, Alterations and Updates 6 04-22-2008 11:40 AM
Wiring Inverter, Converter, and Power Transfer Relays. GeorgeR Modifications, Alterations and Updates 3 01-31-2008 11:50 AM
inverter or converter? Christine V Problem Solving | Owners Helping Owners 0 07-24-2007 12:00 PM
» Virginia Campgrounds
