Inverters - Fiberglass RV
Old 05-21-2003, 11:10 PM   #1
Inverters
Hi. :wave
Could someone please give me a brief explanation of what an inverter does? :conf
Thanks
Barbara
Old 05-21-2003, 11:18 PM   #2
Hi Barbara
Inverters change battery power from 12volts to 110 volts.
Inverters come in different sizes.I have a 300watt inverter so I can run some small house hold appliances.EG 13 inch TV plus VCR or Satelite receiver.Your batteries must be good and inverter should be a close as possible to battery as posible.Other folks will jump in here and may explain it better.:wave
Old 05-21-2003, 11:22 PM   #3
Inverters
Thanks Ches but now I'm confused what does a converter do?
Barbara
Old 05-21-2003, 11:55 PM   #4
Hi Barbara
Converters ---convert shore power(when you have electicity)from110volt to 12volt.I am not good at explaining things.When you are plugged in all your lites run on 12volts in most cases also your furnace and some roof fans,so the power is changed for this purpose.Your wall out lets stay at 110 volts . If you have a battery charger the power not being used will go to charge batteries,if you are using lots of power then your batteries will kick in to help with the power demands.
We have on this forum some people who are really good at explaining things and they will chime in with there knowledge.
Old 05-22-2003, 08:18 AM   #5
In summary,
Inverter = 12 volt to 110.
Converter = 110 to 12 volt.
Old 05-22-2003, 08:26 AM   #6
Thanks, Mary
Inverters and solar panel.
Sun to solar panel to battery to inverter to (small) 110 appliance.
Right?
Old 05-22-2003, 08:31 AM   #7
Inverters
Thanks everyone. I get it now.
Barbara
Old 05-23-2003, 06:30 AM   #8
I think you did an excellent job of explaining that, Ches.
Old 05-23-2003, 04:29 PM   #9
Suz, that's right.
Also keep in mind that the 12V part is DC and the 110V part is AC, so there's more to the change than just the voltage.
Pete and Rats
inverters - too much battery drain? Scott S. Problem Solving | Owners Helping Owners 4 07-18-2008 09:52 AM
Converters, Inverters, LED lights and confusion Camilla Problem Solving | Owners Helping Owners 4 10-23-2007 01:28 PM
Inverters Legacy Posts Problem Solving | Owners Helping Owners 25 04-02-2003 12:15 AM
