Originally Posted by MCDenny
I'm 6weeks late here, but having set up the same exact system ransom is considering I'd like to add that the proper converter (really just a battery charger) is about one-tenth the battery's C20 spec. Has nothing to do with DC loads.
A good energy meter is necessary to monitor your electric use when boondocking. Yes the battery life is extended by stopping discharge before it gets too low but it also lets you predict when it's going to get too low.
I use a 30 amp iota smart battery charger, a 10a PWM solar controller with a 100 amp solar panel, a Victron BVM700 meter and two 6v 220ah batteries.
Note on the BVM700, it uses a 500 amp shunt and resolves current to 10ma, that's 0.01 amps.
Denny Wolfe
Wanderingourway.wordpress.com
Whether a 30 amp converter is large enough depends on a number of things. Do you plan to winter camp with a roof top
solar panel (when the sun angles are low & the days are short? Depending on your amp hour usage, you may find you need more than a 100 watt panel (I think you have a typo of 100 amp
solar panel - that would be great, but would cover the roof of most houses).
The solutions are more panels, portable panels that can be aimed at the sun, a
generator, or hooking up to a pedestal for a couple of days every week or so.
If you are going to use a
generator to recharge your batteries, a larger converter would be useful because the higher initial charge rate would cut down the
generator run time. If you plug into a pedestal every couple of days, you will be able to deal with the longer time the smaller converter takes to charge the batteries, and possibly not need the generator.
Personally, I prefer to depend on solar alone. I have 195 watts (2 panels) on the roof & a portable 160 watt panel. I don't need the portable during the summers, but do during December & January, even in the Arizona desert. I use around 35 - 40 amp hours per day & also have a pair of 232 amp hour batteries. I don't carry a generator, and survived 93 days wintering in Quartzsite without hookups.
