Is 35 amps enough capacity for a charge controller? - Page 4 - Fiberglass RV
Old 05-30-2016, 12:22 PM   #43
Originally Posted by MCDenny View Post
I use a 30 amp iota smart battery charger, a 10a PWM solar controller with a 100 amp solar panel, a Victron BVM700 meter and two 6v 220ah batteries...
Thats a typo.. he means 100 watt solar panel (or about 5.6 amps in actual use).
Old 05-30-2016, 01:47 PM   #44
Raz
Raz's Avatar
Vermont
Note on the BVM700, it uses a 500 amp shunt and resolves current to 10ma, that's 0.01 amps.
From the BVM 700 spec sheet they list the shunt resolution as 50 mV for 500 amps.
So 50 mV/500 amps = 0.1 millivolts per amp shunt resolution. That's 100 microvolts for each amp of current flowing through the shunt.
So a 10mA current through the shunt will produce a voltage of 1 microvolt. That's one millionth of a volt.
Read 10 mA.? Sorry Denny, but this old engineer is skeptical. Raz
Old 05-30-2016, 04:54 PM   #45
MCDenny's Avatar
Trailer: Lil Snoozy
100 amp solar panel, I wish. Of course I meant 100 w, which only puts 65 watts into the battery.
Trojan battery charger specification is10% to 13% of battery C20 rating.
Re the BVM 700 meter, they say 10mA but I hear you Raz.
Denny Wolfe
Wanderingourway.wordpress.com
MCDenny is offline   Reply With Quote
AC/DC Koolatron fridge uses 6 amps on DC Radar1 Modifications, Alterations and Updates 5 10-13-2013 06:29 AM
Bigfoot 17CB Amps? Francine P Problem Solving | Owners Helping Owners 3 06-25-2010 05:15 PM
Installing a digital Amps/Volts Meter peterh Modifications, Alterations and Updates 21 09-10-2009 03:37 PM
Solar charge controller yvonne Care and Feeding of Molded Fiberglass Trailers 24 06-26-2008 05:46 AM
Fluid, Battery Levels & Solar Charge Controller? peterh Electrical | Charging, Systems, Solar and Generators 9 04-27-2007 04:45 PM
