LED lights - Fiberglass RV
Old 11-30-2011, 03:10 PM   #1
Trailer: 1984 UHaul CT13
Question LED lights
Need some info. I don't have a shop, don't know much about electrical, and less than that about replacing interior lights. On my UHaul I have the original light fixtures, one above closet and the other above the sink. They are florescent 8 watt little tube lights. There is something in the range hood but I havent even looked at it. What kind of LED lights can I replace the tubes with and hopefully I just plug them in to where the tube would go. Help and info gratefully appreciated. Thanks, Patti
keekers is offline   Reply With Quote
Old 11-30-2011, 03:54 PM   #2
cpaharley2008's Avatar
once you determine the type of bulbs you need, size,type of base go to here
LED Lights, Bulbs & Accessories - SUPER BRIGHT LEDS and look for your replacements. Their technical support is great if you are not sure.
Old 11-30-2011, 05:34 PM   #3
Raz
Raz's Avatar
Hi Patti. Lots of good posts on this one. My suggestion is to try using the search feature. I bought my LEDs from Superbright. Some folks have had good luck with eBay aswell. As far as the florescent tubes, you will need to replace the whole fixture. An RV store will stock those. Raz
Old 11-30-2011, 07:10 PM   #4
Trailer: 17.5 Bigfoot
I just went through the same process for my Bigfoot. Found it was cheaper and easier to just replace the whole fixture with these new Kaper 11 LED units. They give off a nice white light and are quite stylish. They come with double or single Leds and are on sale right now. One unit even has a nice blue night light built in. Simple 2 wire hook up.
Kaper II LED Lights
Kaper II LED Lights
Kaper II LED Lights
Just now checking the Panther web site, I see they have added the same style light with warm white [3500K] LEDs, so you have a choice for color temperature. Best to phone them and place an order.....very helpful.
Don Dunsmore is offline   Reply With Quote
Old 11-30-2011, 07:22 PM   #5
The range hood swap may take some research. I used this LED set up from China. Bright white light and comes with various plug in adapters. Has double sided tape for attaching to fixture. Cheap and works well.
T10 36 SMD LED Light Festoon Dome Bulb Lamp White 12V | eBay
Old 11-30-2011, 07:57 PM   #6
Thanks Jim, Raz & Don,
I was hoping not to have to replace the fixtures or re-wire anything, just wanted to change like a household lightbulb, without having to pay rv store 80-95$$ per hour to make a change. I'm still hoping there is something I can do myself. I will call Panther tomorrow and talk to them. Thanks guys!
Patti
Old 11-30-2011, 11:57 PM   #7
David Tilston's Avatar
Patti
If you want to change them because you want to save power, I would just like to point out that fluorescent and LED are similar in efficiency.
If it's a quality of light issue, I can't argue with you. I did however just install a florescent over my stove. The LED's I am still researching. I want them to replace the low efficiency brake lights that are everywhere else.
Old 12-01-2011, 09:02 AM   #8
Dave,
Not a quality of light issue at all, I really don't have the interior lights on very much at all. I use a battery powered lantern for the short times spent in the trailer. I was thinking there might be a small power savings but like your point about florescents also being efficient. Brake lights are another issue since I'm sure you have read how bad the Uhaul taillight lenses can be--mine are no better and I'm even hesitant to try to remove them, the rubber seal is already in sad shape. Wish there was someone local that had an egg to talk with and show me stuff about my trailer. I will continue my quest for that.
Thanks,
Patti
Old 12-01-2011, 01:45 PM   #9
Roger M's Avatar
Assuming boondocking is your main mode of camping, then LED's are among the first on the list to do. Google is your friend - remove and ID the lamps in question and search the term with "led". Same with eBay; I bought several bulbs cheap from China that way and am happy with them.
For trailer brake lenses there are several inexpensive light abrasive glaze removal products available in auto parts stores that will help "shine the light" and brighten up the brake lights. LED's are not needed there since the tow vehicles alternator supplies the juice. If however you want brake LED's buy the red ones since white LED's will change the color to pink.
Roger M is offline   Reply With Quote
Old 12-22-2011, 07:57 PM   #10
Trailer: U Hall VT
I thought LED's saved on the battery over fluorescent
Roger Kimble is offline   Reply With Quote
Old 12-22-2011, 08:00 PM   #11
I think LED's do save more on battery but you get much more light with a fluorescent, so maybe per lumen they are eqivalent.
Old 12-22-2011, 08:47 PM   #12
I have both, well Cold Cathode Fluorescent Lights, and LEDs.
CCFL 2 12" bulbs together draw 0.5 amps. Enough light to light the kitchen area in my 13' as do most things, not quite enough for reading at the dinette.
LED lights - replacement bulbs in 3 fixtures, 2 additional fixtures over the dinette/bed. Less than 0.2 Amps per fixture.
Original incandescent lights - 1.5amp each.
Right now with all lights on including the porch light I draw about the same amount as with a single original incandescent light.
Watch for the next generation of household lighting, it will LED. Some are available, but the cost is still high, that will change in time.
Old 12-23-2011, 01:50 PM   #13
Trailer: 1980 Burro
I always thought that LED was significantly more efficient than fluorescent and the web sites below seem to say that LEDs use 1/2 to 1/5th the amount of power to produce the same amount of light.
In the paragraph on energy consumption, this web site says LED's are about 5 times more efficient than fluorescent.
LED Vs. Fluorescent Lighting | eHow.com
In the first paragraph on this web site it says that LED's are 2-3 times more efficient than fluorescent. In a later paragraph it also points out that fluorescent uses an iron core transformer that reduces efficiency even more. They also have some tube type LEDs that they call LED fluorescent, but they use a different power source so they can not be used in existing fluorescent fixture.
led ceiling light,led street light,led street lamp,high power led,led light bulb
Andy B is offline   Reply With Quote
Old 12-23-2011, 04:31 PM   #14
What LED fluorescent bulbs are referring to is replacement bulbs for fluorescent lights.
Old 12-24-2011, 12:47 PM   #15
Trailer: U Hall VT
Compare: LED Lights vs CFL vs Incandescent Lighting Chart
Here is a site that shows useage
Old 12-24-2011, 01:42 PM   #16
LED efficacy
I would be careful with some of these efficiency claims especially if they use 60W incandescent bulb as reference point instead of lumens/watt. There are some LEDs with 250 lumens/watt efficacy but it will take some time to see them in real life. The following two PDF documents could have too much information but it is good stuff. One is from 2008 and the other one from 2009 but I still think they are relevant.
http://apps1.eere.energy.gov/buildin...white_leds.pdf
http://cool.conservation-us.org/byor...white_leds.pdf
George.
energy_efficiency_white_leds.pdf (applicationpdf Object) - Mozilla Firefox 12242011 113523 AM.bm.jpg   comparing_white_leds.pdf (applicationpdf Object) - Mozilla Firefox 12242011 111548 AM.bmp.jpg
Old 12-24-2011, 02:14 PM   #17
George.
Don't be mislead. These comparisons are lamps used in household current fixtures. LED's are approximately 2volt devices and DC devices, perfect for 12 volt trailers. However they require some different technical stuff for 120AC applications.
My measurements for an 1157 LED replacement lamp
Current = .2 amps
Power = (.2x12) 2.4Watts)
Lumens = 252 (per specifications)
efficiency in Lm/W = 252/2.4 105 Lm/W
In this case the efficiency in Lumens per Watt is higher for LEDs than any other light.
I agree with the findings shown in those documents for 120VAC applications. It's a bit more difficult to efficiently alter AC to work with DC devices, than to use DC devices with DC. However, improvements are happening rapidly.
I won't go into all the technical jargon to explain why.
Old 12-24-2011, 03:08 PM   #18
Get the Alternating Supply down to the correct voltage and the LED works without a problem as a half wave rectifier.
Take your Christmas LED rope light and wave one end back and forth with the light on and it will appear as though the light is blinking on and off and that is because it is only on during ½ the AC cycle.
If it does not blink on and off when you do that then it is full wave rectified and turned on , on both cycles of the AC
Old 12-24-2011, 03:23 PM   #19
Agree, and if 30/25Hz is too annoying full wave bridge is just a little more money.
George.
Old 12-24-2011, 05:42 PM   #20
That also means only half the light output.
lights
LED trailer lights / Non LED lights on tow vehicle Kevin K General Chat 20 11-24-2010 12:05 PM
LED lights Francine P Problem Solving | Owners Helping Owners 12 04-03-2009 09:29 PM
LED lights in Original light sockets - tail lights Cam A Modifications, Alterations and Updates 75 02-15-2009 11:54 PM
LED Lights Dave Mac Problem Solving | Owners Helping Owners 9 07-24-2007 04:44 PM
NEW LED LIGHTS!! Christi V. Modifications, Alterations and Updates 12 05-10-2007 09:10 PM
