Led's not working - Fiberglass RV
Old 08-20-2012, 11:53 PM   #1
Perry J's Avatar
Trailer: 16' Casita
Led's not working
Will on over voltage make LED's inoperative?
I was cleaning my Lil Bigfoot today and for ther first time I turned on the interior lights during the day and they didn't work.
They have always worked when needed in the late afternoon or evening.
I changed all the light fixtures and installed the LEDs before I installed the solar panel.
I was out in the yard tonight and noticed a light on in my trailer.
It's dark and everthing is working like it should.
I noticed my Solar panel was putting out a little over 14 volts this afternoon.
Do I need to install a resistor in the light circuit?
John
Old 08-21-2012, 05:01 AM   #2
Ron F's Avatar
Trailer: Eggless for now.
Formerly NH, now full timing
John,
Overvoltage will damage your LEDs, which will render them inoperative, permanently. I doubt that they would come on again later unless there was some type of photocell circuit that prevented them from coming on in daylight.
Either way, I'd suggest adding voltage regulator chips to your lighting circuits. Radio Shack sells 12v regulators for a couple of bucks. LEDs are expensive and the protection is cheap.
Ron
Old 08-21-2012, 05:35 AM   #3
Raz
Raz's Avatar
Vermont
I agree with Ron, if they come back on then over voltage didn't damage them. Sounds like a loose connection to me. If it only happens during the day, I would suspect an open due to temperature.
Ron's comment about a photo cell makes me wonder, I have some puck lights with photo cell circuits to prevent day time operation. You're not using those are you?
As far as voltage regulators, the better LED fixtures have both polarity and regulation circuitry to eliminate those concerns. Adding an additional regulator might be redundant. Raz
Old 08-21-2012, 07:39 AM   #4
Trailer: Casita 17 ft DLX SD
I would check the voltage at the fixtures . My Led fixtures give off little light with low voltage which is not easy to see during the day but at night the light shows up.
Old 08-21-2012, 09:49 PM   #5
Perry J's Avatar
Trailer: 16' Casita
They were working today so I think I may have a poor connection somewhere.
Thanks all,
John
how to find working LED bulbs? LukeP Electrical | Charging, Systems, Solar and Generators 21 07-15-2012 07:29 PM
1895 incand. bulb LED replacement NOT working! Paul Chet Electrical | Charging, Systems, Solar and Generators 24 04-08-2012 10:47 PM
LED trailer lights / Non LED lights on tow vehicle Kevin K General Chat 20 11-24-2010 11:05 AM
Who's working, anyway? David G. Jokes, Stories & Tall Tales 8 01-23-2007 10:42 AM
Battery - Not Working Jeremy Witt Problem Solving | Owners Helping Owners 7 06-17-2006 09:08 PM
