Magnatek power center parts. - Fiberglass RV
Old 08-12-2015, 11:05 AM   #1
Does anyone have an old Magnatek power center from a camper that they are willing to part out? I need a relay for an older unit.
My unit is a model number 6325. Other models might also have the same piece. Scamp and Casita both used this model in the past. I don't know about other brands but I believe it's pretty common.
Gene Masse is offline   Reply With Quote
Old 08-12-2015, 11:09 AM   #2
Here is a pic of the part.
It is in the bottom half right front.
Old 08-13-2015, 11:42 AM   #3
Trailer: 13' burro, 13' casita, 20' nomad f/w
Google it;
gcssr39 is offline   Reply With Quote
Old 02-16-2016, 03:56 PM   #4
Dudley's Avatar
Trailer: 1998 Casita 17 SD
Hi Gene, I had one last year but think I tossed it in the fall. You should be able to sub in any 12 volt single pole double throw relay with around 30 amp contacts. If its not charging then it may be the load resistor or the fuse (in a black box )next to it riveted to the rear of the converter section. Here is a link to a good troubleshooting guide magnatek
BTW if it is the resistor, I have a couple here that I can send you.
Old 02-16-2016, 04:05 PM   #5
Thanks Dudley, I found a replacement from a company in Minnesota. It's slightly different in how it's set up but otherwise the same item. I wouldn't mind an original but this will do ok.
Parts Parts Parts Ken Gronsdahl Classified Archives 5 07-06-2008 11:05 AM
magnatek vs progressive dynamics Legacy Posts Problem Solving | Owners Helping Owners 2 05-25-2003 08:40 AM
Magnatek Series 6300 A Model 6365 Legacy Posts Problem Solving | Owners Helping Owners 2 12-30-2002 12:51 AM
