MagneTek Power Converter 6325 Not Working - Fiberglass RV
Old 06-24-2014, 06:13 PM   #1
Rhea and Kirby Coolen's Avatar
Trailer: Bonair
Nova Scotia
This was standard equipment in our Bonair Oxygen.
Unfortunately it doesn't seem to be charging the battery, which is now only showing 10 volts, whether plugged in to 110 or not.
I have done some basic checks but have no quick solutions yet. Any suggestions on a repair, modification, or an upgrade would be appreciated.
- Kirby
Rhea and Kirby Coolen is offline   Reply With Quote
Old 07-01-2014, 01:28 PM   #2
Trailer: 1999 Casita 17' SD
Ohio
First remove the battery and using a conventional charger to verify the battery's condition.
There's a fuse inside the unit in the lower left and if it's blown the battery won't be charged.
If your unable to find the manual in the document section I can send a pdf of the information for the 63xx series convertors. Drop me an email and I'll send it along.
J
Old 10-12-2014, 11:50 AM   #3
Trailer: Bonair
Did you find a solution? I own a Bonair Oxygen too and recently I noticed our Magnetek 6325 is not charging the battery.
I found these solutions:
PD4635 35 Amp Converter Upgrade Section
and
this step by step: Converting the MagneTek 6325 Charger/Converter to the
using this product: Inteli-Power PD9160A
with the Charge Wizard.
I am curious to know if you selected either of these or found another solution. I am hesitant to replace a 25 AMP converter with a higher power converter.
grimjed is offline   Reply With Quote
Old 10-12-2014, 12:45 PM   #4
A "Higher Power" converter only means that it can support more DC accessories if desired. At that, at full power, a 60 amp converter will draw less than 3.5 amps more than the 25 amp converter on the ac shore power line. With your existing loads it will draw only a minimal amount, maybe an extra .1 amps.
BTW: I am very partial to the Progressive Dynamics line and recommend that entire MagnaTek units be replaced with a Progressive Dynamics PD-4045 power center.
Old 10-12-2014, 01:59 PM   #5
Dudley's Avatar
Trailer: 1998 Casita 17 SD
I have the same problem and was going to repair it but decided on upgrading. I found the info on the original. Megatek repair
If you decide on repair , I can sell you the resistor you will probably need( I bought 2 for mine but never used them.
Old 10-13-2014, 09:12 PM   #6
Dan Meyer's Avatar
I gave up on converters after my second one went bad less than a year after being installed. I hard wired a battery charger in as an alternative. See http://scamp.n0kfb.org/ and click on modifications and repairs.
-- Dan Meyer
Old 10-13-2014, 10:22 PM   #7
Somehow, at least "I" think, that a BonAir without a complete & modern electrical system w/converter would be like unguilding the lilly.... and would certainly have a negative effect on it's resale value.
Old 02-15-2015, 02:42 PM   #8
Trailer: Bonair
Nova Scotia
Sorry for the delayed reply. It turned out that our battery itself was the problem. Replaced it and all was fine. Now we are anxious for May and a return to camping.
CONVERTER not working Adrian W Electrical | Charging, Systems, Solar and Generators 15 07-28-2014 12:21 PM
Magnetek converter Shadow56 Electrical | Charging, Systems, Solar and Generators 10 04-07-2014 05:06 PM
93 Bigfoot 17CB - Magnetek Converter BAD! Michael Pupeza Problem Solving | Owners Helping Owners 18 08-24-2007 08:18 PM
Magnetek 6325 circuit breaker Yves Pelchat Problem Solving | Owners Helping Owners 2 09-29-2006 07:52 AM
magnetek 3220 Legacy Posts Problem Solving | Owners Helping Owners 10 12-13-2002 11:32 AM
