Main fuse location - Scamp owners - Fiberglass RV
Old 07-23-2013, 05:38 PM   #1
Trailer: Scamperless
On the wiring diagram it states that the main battery fuse is located under the front bunks. But I have a front bath. I see where the wiring goes into the trailer from the outside, but I see nothing in the front cabinet on the inside or underneath the camper. I've checked everywhere that I know of and have not found a mainline fuse on my camper. Anyone know where the main battery fuse is located on 2008 Scamp custom deluxe? Or isn't there one?
Jerry71 is offline   Reply With Quote
Old 07-23-2013, 06:45 PM   #2
Trailer: Casita 17 ft DLX SD
Fuse
My Scamp had a fuse inside the battery box located on the trailer tongue
Old 07-23-2013, 06:53 PM   #3
Ed Harris's Avatar
I have seen the main fuse buried under the Rat Fur right where you see the wires come inside from the tongue.
I imagine that you can feel the bundle under there if it is there?
So if you can track where the bundle enters the trailer the fuse should be right there.
Don't know why but......
I have seen this on several Scamp of different sizes too.
Old 07-23-2013, 07:19 PM   #4
The one inside the battery box is one two. The other is inside the trailer.
Old 07-23-2013, 07:22 PM   #5
Ed, thanks. There is some carpeting that is glued to the rat fur in the closet next to the bath that may be covering up the wires and fuse. I will pull it back to see if it located there. I don't know if there is suppose to be carpeting in there or not (I didn't buy this unit new). It is a deluxe model so maybe the carpeting in there comes standard. It matches perfectly with the carpet on the floor in the main section of the trailer. I didn't think it would be necessary to remove capeting if you had to replace a fuse, but maybe.
Old 07-23-2013, 07:49 PM   #6
It should be inside the closet right where it comes inside, probably close to floor level but covered by the rat fur.
Let us know where you find it, the info will help others
Old 07-23-2013, 08:40 PM   #7
Trailer: none
On my 96 front bath (standard) wires/fuse bunched up under carpet in front closet
Hambone is offline   Reply With Quote
Old 07-23-2013, 08:51 PM   #8
fuse location
I forgot about the fuse in the front closet . I put a 30 AMP fuse in the front closet fuse holder and a 20 or 25 AMP fuse in the battery case fuse holder (can't remember)
That way the fuse in the battery case blows first where it is a lot easier to access then unloading the closet . If both fuses are 30 amp it's a tossup on which fuse will blow
Scamp 16 Toilet Location? Ryan P R Plumbing | Systems and Fixtures 3 08-07-2012 09:39 PM
Scamp 16 - installing new fuse panel / 12v convertor John Carter Problem Solving | Owners Helping Owners 2 03-19-2012 11:49 AM
Scamp VIN location Myron Leski Problem Solving | Owners Helping Owners 3 10-08-2010 07:31 AM
Main fuse? Wilder Problem Solving | Owners Helping Owners 2 12-21-2009 10:17 PM
Optional Location for A/C in new Scamp 13? melissab Problem Solving | Owners Helping Owners 7 12-11-2009 08:40 PM
