More electrical updating advice needed - Page 2 - Fiberglass RV
Old 07-06-2013, 07:23 AM   #15
Trailer: Casita 17 ft DLX SD
Self resetting over current devices often cause as many problems as they solve . If a piece of equipment faults the breaker keeps trying to reset often until it destroy itself or the piece of equipment. Automatic resetting circuit breakers are especially dangerous when used with rotating or moving equipment . Circuit breakers are electric/mechanical devices and often corrode internally changing the trip point and are supposed to be exercised on a regular basis Fuses may be low tech but they consistently work. I agree with Mr. Miller start with a good converter and eliminate a lot of problems
Old 07-06-2013, 09:57 AM   #16
Add to Steves comments that regular switch type AC circuit breakers also change value as they age, especially if they are used as on/off switches on a regular basis. New breakers for most panels are in the under $10 range and new ones are always a good idea on older panels.
Old 07-06-2013, 10:14 AM   #17
Trailer: '77 Scamp
Thanks for the additional info. I checked out installation for Bob's PD 4045 on the net last night. Yikes...I hope and can do that--seems complicated. So forewarning Bob. You may be tapped for LOTS of questions.
Otters is offline   Reply With Quote
Old 07-06-2013, 10:49 AM   #18
Roy in TO's Avatar
Originally Posted by hotfishtacos View Post
These controllers are designed to either control the solar charging of the batteries or act as a load controller from the batteries to the load, but not both.
Perhaps the simple controllers, mine was designed for both. It also has a USB connection to download data to a computer. I can keep track of charging and loads for up to a year.
Old 07-06-2013, 11:10 AM   #19
hotfishtacos's Avatar
Trailer: 2012 Escape 19' /2010 Honda Pilot 4WD TV
Escondido, California
Steve, it's standard practice to use self-resetting circuit breakers in RVs on the circuits we have been discussing. These are specifically designed for vehicles with DC applications. My Escape 19' has several of them wired in from the factory. I will bet your Casita has one between the battery and the distribution panel. If you think it is dangerous and will corrode over time maybe you should remove it.
"No Generators"
hotfishtacos is offline   Reply With Quote
electrical
Electrical Wiring work needed Jackie R Modifications, Alterations and Updates 1 10-20-2013 08:43 PM
'77 Scamp Electrical Help Needed Otters Electrical | Charging, Systems, Solar and Generators 30 03-17-2013 03:45 PM
Advice Installing Power / Electrical from Scratch RussP Electrical | Charging, Systems, Solar and Generators 19 04-10-2008 12:52 PM
Electrical help needed Pam Garlow Problem Solving | Owners Helping Owners 6 11-20-2007 12:35 PM
Advice Installing Power / Electrical from Scratch RussP General Chat 0 12-31-1969 07:00 PM
» Trailer Showcase
Ferb
OR335d
1963 Aladdin
Loyce
