Mppt Vs PWM solar chargers - Worth it? - Page 2 - Fiberglass RV
Old 11-27-2018, 08:06 PM   #21
To clarify the testing of the solar system here the sun was bright, but the angle was not nearly perpendicular (winter in North Florida with flat panels) and the battery was charged so I turned on the lights etc to get current flowing in both the panels and the output.
The system may behave differently when bring up a battery from 50 or 70% to 100%.
If the PWM works for you and you get the charging you need then you are good to go.
You could also add another panel to make up the difference and more in efficiency or rather output, but perhaps you don't have the space for it (them).
By the way If someone wants a discount on a one of two slightly used PWM controllers, let me know. Tested and found to be mediocre
Old 06-17-2021, 01:17 AM   #22
Trailer: Yamaha
Hi....The PWM regulators that I have (modest ones) are auto exchanging for 12v or 24v battery. Yet, for 12v they say the information voltage is 25v or thereabouts and for 24v information breaking point would be 50v. I think they need to try not to see an enormous distinction between the information and the battery being charged. The MPPT regulators permit bigger contrasts (regularly) and improve execution when the isn't solid on the boards.
If it's not too much trouble, incorporate the battery voltage and on the off chance that you have your 3 boards in arrangement or in the event that you have them in equal.
BabbRust is offline   Reply With Quote
Old 06-17-2021, 08:20 AM   #23
David Tilston's Avatar
I'm sorry. WHAT?
Old 07-05-2021, 05:34 AM   #24
Trailer: Scamp 1995 19'
Originally Posted by David Tilston View Post
I'm sorry. WHAT?
I'm thinking a language difference.
JWColby EAAT
Exalted Arbiter of Anal Tripe
jwcolby123 is offline   Reply With Quote
solar
How Do I Size MPPT Charge Controller? Huck Electrical | Charging, Systems, Solar and Generators 9 07-17-2018 03:18 PM
PWM vs MPPT...explained... Franswa Electrical | Charging, Systems, Solar and Generators 1 07-14-2018 08:43 AM
115V and solar chargers active at same time?? FRL001 Electrical | Charging, Systems, Solar and Generators 20 06-29-2017 05:16 PM
PWM Motor Speed Controller Regulator Night Sailor Electrical | Charging, Systems, Solar and Generators 36 07-14-2014 09:47 AM
Solar Battery chargers 81scamp Problem Solving | Owners Helping Owners 3 08-23-2011 07:09 AM
