Need schooling in AC/DC outfitting - Fiberglass RV
Old 05-24-2014, 03:52 PM   #1
Beverly Jones's Avatar
Trailer: 1975 Boler
I know one works off the battery, and the other from outside plug-in.
I have a deep cell battery for boon docking, also propane for heating, cooking, and refridge, and the ability to plug the trailer into an outlet.
What's the best layout for both?
I want to be able to light with both, occasionally watch a DVD on my 15" TV , and plug in my computer.
I imagine using LED lighting will save on battery consumption, as will as plug in consumption.
I'd also like to be able to run a small interior fan, in hopes it will help keep the condensation down, even when in storage.
Requesting suggestions.
Thx,
Bev
Beverly Jones is offline   Reply With Quote
Old 05-24-2014, 05:41 PM   #2
It sounds like you need to update all of your light fixtures to LED's so that they will run off of the battery with minimal draw. Then a small inverter (that converts 12 VDC to 120 VAC) for occasional 120 use, such as for your TV/DVD player or your computer. There are inverters that will just plug into your 12 accessory outlet than can power the TV/DVD player or a laptop/tablet computer without any additional wiring required.
Does that help?
is your current system designed to also charge your battery when you are connected to shore power? Does your vehicle also charge the FGRV's battery when towing? Hopefully those are both YES questions.
A small heads up, don't make use of an inverter when you are plugged in with the shore cord and charging the battery. Many of the older battery chargers don't get along well with the electronics in computers.
Old 05-24-2014, 05:59 PM   #3
Trailer: 1975 Boler
I just had 2 new batteries installed, one under the hood of my Subaru, and the other on the tongue, by the propane tanks. .. hoping they are the non-fussy type.
I will need to look to see if an invertor was installed. When I took the Boler to the RV shop I asked that one would charge the other, and I hope that also means they will charge when plugged into shore power.
So, it sounds like all I should install are 12v LED lights? I hope to get rid of having to have 2 lights installed under the galley cabinet.
Old 05-24-2014, 06:31 PM   #4
Yep, 12 volt LED lights would be the order of the day.
An easy way to find out if your vehicle is also charging your coach battery is, with the shore power unplugged, turn on all of the 12 volt lights in the trailer and then start the car. They should get a bit brighter with the engine running.
BTW: Are you anywhere near Chelan, WA
Old 05-24-2014, 08:03 PM   #5
cpaharley2008's Avatar
Here is a starting reference point The 12volt Side of Life (Part 1)
Jim
Never in doubt, often wrong
Need rear sliding window channel with flocking - need exact part number idiotsniff Problem Solving | Owners Helping Owners 16 06-27-2013 08:45 PM
Outfitting the trailer for full hook up camping Lainey Care and Feeding of Molded Fiberglass Trailers 7 07-09-2008 09:28 PM
