Need some help with wiring on 1986 Scamp - Fiberglass RV
Old 05-30-2013, 11:24 AM   #1
Trailer: scamp
Montana
i just got my first Scamp a few weeks ago and of course the old rancher that i got it from did some funky stuff i think..does any one have a diagram of what the wiring should be ? thank you derek
montanascamp is offline   Reply With Quote
Old 05-30-2013, 12:06 PM   #2
Steve Hammel's Avatar
Trailer: Hymer Touring GT
Loon Lake Wa. and Boulder City, Nv.
Hey Derek, at the top of the forum page, to the right, click on "more" and then select document center. I believe you will find all the documentation you will need for your wiring and everything else.
Old 05-30-2013, 12:10 PM   #3
Thomas G.'s Avatar
Trailer: For Sale Or Rent
Rooms to Let 50 Cents
Check this out. Fiberglass RV - Document Center - WiringDiagram_Scamp
Old 05-30-2013, 06:53 PM   #4
Be a little more specific about what is wrong with your wiring. I'm sure someone on here has experienced the same problem.
Old 05-30-2013, 08:58 PM   #5
Trailer: scamp
Montana
Can't get any inside lights to work..i guess i will have to bribe you to help me when i see you !!!!
Old 05-30-2013, 10:25 PM   #6
Did you put a meter on your battery? Do you have any power?
Do you have a florescent light in your kitchen that runs only on shore power only - does it work?
Do you have a converter? You may find some fuses inside the converter box that may be blown assuming you have already checked the two inline fuses - one at the battery and one just inside the trailer where the wiring comes into the trailer on the passenger side. Often inside the hatch behind the wall covering.
Old 05-31-2013, 04:10 AM   #7
Do you have an "on board" battery or just when it is connected to the vehicle?
Old 05-31-2013, 05:07 AM   #8
Trailer: scamp
Montana
i have both, but its on just the battery now and plugged in to 110.thanks
Old 05-31-2013, 06:01 AM   #9
Good. That takes the 7 pin out of it for the moment.
Old 05-31-2013, 06:03 AM   #10
First thing I would check now are your grounds on the frame. Do you know if you have power out of your convertor?
Old 05-31-2013, 07:50 AM   #11
GMike A's Avatar
Derek
You can usually place you hand on the converter and feel it humming or the minifan blowing as a start. Invest in an inexpensive test probe with a LED light and an alligator clip that checks for 6/12 vdc.
Im sure you will nail it down with all the help onboard.
Mike
K5NAN
"Miss Adventures"
If you Rest, You Rust
Old 05-31-2013, 09:28 AM   #12
Trailer: 2014 Escape 21, Lil Joe
If it's an older Scamp W/O converter it has two fuses in the 12V system. One on the outside near the battey. (Sometimes long gone.) The other is under the front bench on the drivers side. ( Near where the wires come into the shell.) This is for all the inside DC stuff.
Eddie
Old 05-31-2013, 10:05 AM   #13
My 1986 Scamp 13 didnt have a converter 12 volt Dc and 120 volt Ac were divorced. 12 volt had one 20 amp fuse at the battery no fuse inside.
1986 Scamp 13' for sale Bill White Classified Archives 2 04-25-2010 01:16 PM
just bought 1986 13' scamp Steph H General Chat 15 07-13-2009 11:29 AM
SOLD - 1986 Scamp 16' llollio Classified Archives 3 06-24-2007 11:27 AM
1986 Scamp in Cal. John Perry Classified Archives 0 11-01-2006 08:37 PM
just bought 1986 13' scamp Renee R. Fernandez Classified Archives 0 01-01-1970 12:00 AM
» Trailer Showcase
The Pod
Erin C
Trillium
Glen_
