Never a thought - Fiberglass RV
Old 07-18-2015, 11:11 AM   #1
Carl Pa's Avatar
Never a thought
As to being plugged into shore power and the battery still going dead. My AC was not working on a very hot day while camping at French Creek PA State Park this past week for five days, (The AC not working is another issue) So i was using the lights and fantastic fan heavily and i guess it drew down the battery completely. I was under the impression that as long as you were plugged into shore power you would be OK, i guess not, I have one battery, group 24, standard in scamps. So what i learned is that you always have to be aware as to how much and how long you can use your 12V appliances weather or not you are plugged in or not.
Carl Pa is offline   Reply With Quote
Old 07-18-2015, 11:16 AM   #2
There's something wrong. Most likely the circuit breaker at the power pole, the one you're plugged into, has blown. As long as you really do have 120V AC your air conditioner should be working, and battery charged. The converter supplies enough energy to power everything in your trailer.
Old 07-18-2015, 11:49 AM   #3
I believe your Scamp will have a Progressive Dynamics PD-4045 power center and, if connected to the 120VAC you should never have a worry about DC power or battery charging, including accomplishing both at the same time. They just don't get much better or reliable than the PD-4045.
BYW: Do you use a small plug-in power checker when you connect to a power pole? It's a good idea to verify ac polarity as well as to verify that you have AC power. Usually less than $10 at any hardware store.
Old 07-18-2015, 12:33 PM   #4
Carl Pa's Avatar
Thanks for your replies. I really don`t have any checking gizmos, got to get some. The thought came to mind that i used a 30`rv ext cord plus the 30` trailer cord may have been to much distance, not good at this stuff. We are home now, the 2 hour drive home charged every thing up and lights and fan are working fine. However can`t check AC because i only have a 15 amp receptacle in garage where i plug into at times. Will wait till i camp again in a couple weeks to check, before i lay out cash at a RV shop. The site i was at was not good, if i went back further i would have my wheels in mud and would not have anything stable to set up, so i stayed forward to avoid it and used the RV ext. cord. to connect to power. If you look at photos you can see what i mean. Carl
Old 07-18-2015, 12:46 PM   #5
John Linck's Avatar
Madison, Wisconsin
The extra distance should not be a problem unless you extension cord is defective. As Bob said pick up one of these at your local hardware store to find out where things are amiss. There are many different brands. Any will do. Should cost about $7.00.
The 15 amp at home will be plenty to test whether the power is getting to the trailer.
Good luck, john
John Linck is offline   Reply With Quote
Old 07-18-2015, 12:47 PM   #6
Go to WalMart or an RV store and get a 15/20amp adapter for your cord, so you can plug in at home, you will have a lot of use for it in the future. They will also have the outlet checker you should have.
Admittedly, 60' of cord may have caused a problem for your a/c, but the converter should have run just fine.
Best to sort out any problems before you go out again.
Old 07-27-2015, 06:25 AM   #7
rdickens's Avatar
Trailer: 2017 Scamp 16 Deluxe
I had a similar issue with our Scamp13. Battery was not recharging when connected to shore (110v) power.
It turned out to be a blown fuse (one if the top 2 fuses IIRC).
I think that your battery should recharge from either shore power or the 12v hot lead from your tow vehicle.
Good luck! As always, YMMV. 😉
Ray
rdickens is offline   Reply With Quote
Old 07-27-2015, 10:31 AM   #8
Carl Pa's Avatar
Hi Ray. checked the fuses, they did not look blown, but i am not good at this stuff, for the cost of a fuse i guess i should buy some and replace the old one and see what happens. I bought a mutimeter, trying to find out how to operate and understand it. Thanks for your tip, i will try it. She is charged fine at TV. I always have AC from shore power but not DC coach lights, pumps, etc. Carl
Old 07-27-2015, 01:14 PM   #9
Mike Magee's Avatar
Trailer: Li'l Hauley
The A/C was not working and the battery went dead. I'd bet that the circuit breaker at the post was popped or the main breaker in the trailer was popped. This would cause you to get no power from the CG's post, which would let battery-run items operate but not the A/C... until the battery went dead for lack of recharge.
Now, if you had a microwave or any other household-current appliance operating while at that CG, this would disprove my hypothesis.
If you've plugged it in at home and the battery charged up again, then it was the breaker on the CG post where you plugged in.
In the '60s, people took LSD to make the world seem weird.
Now the world is weird, and people take Prozac to make it seem normal.
Old 07-27-2015, 02:33 PM   #10
Connecticut
Battery dead and no AC
Hey Carl,
I would agree with several of the previous posters. While bringing our new Spirit Deluxe home from Rice TX. I camped at a COE campground in Barling Arkansas. I plugged in the camper went inside turned on a couple of lights, the Fantastic Fan and thought I was in business until I went to charge my cell phone. I noticed that the phone was not charging and proceeded to investigate, sure enough the circuit breaker had tripped at the post. We learn as we go and that was the first of many lessons, happy camping and you'll be a veteran before you know it.
wwig is offline   Reply With Quote
Old 07-27-2015, 04:19 PM   #11
Carl Pa's Avatar
Mike, Coffee pot, electric fan, thank god was working. All 110 current was working. Accept the AC.
When we were ready to go home, the minute i plugged into the suv. all lights came on. They all work (10 days) so far with the 2hr drive home. Carl
Old 07-27-2015, 04:22 PM   #12
Carl Pa's Avatar
Thanks every one for your help, sure helps when you are not alone. Carl
Old 07-27-2015, 04:53 PM   #13
I believe the OP's trailer is 30 amp as my Scamp is. So they would needed a 30 amp to 15 amp.
Old 07-28-2015, 05:32 AM   #14
rdickens's Avatar
Never a thought
If your 110v appliances (fan, coffee pot, etc.) were working (with the exception of the AC), then it sounds like you were getting power from the CG post.
(The AC sounds like a separate breaker or issue.)
If the battery charged up (from the tow vehicle) on the way home, then it sure sounds like the fuse/breaker in the 110vac->12vdc rectifier battery charging circuit might be the culprit.
I carry a cigarette lighter voltage tester in the trailer for checking the battery charge/voltage state. Something similar to this:
http://www.amazon.com/gp/product/B00...sf_s_rp_a1_6_p
I have a very small night light (green light output) that we keep plugged in to an outlet in the trailer. When we connect to shore power (110v), that little night light is a quick visual indication that we are getting 110v power from the post. (I have experienced bad post outlets and balky/faulty breakers from time to time.)
Most multimeters have a continuity tester. If you are on that setting and hold the red and black probes together, the tester will beep. If no continuity tester, use the resistance function to look for 0 (zero) resistance between the probes; then look for 0 resistance from one side of the fuse to the other side.
Hope that helps.
Good luck! 😀
Ray
Testing, Checking, never mind me Gina D. Forum Admin, News & Announcements 38 02-27-2008 01:27 PM
never thought it could happen to me gillian s General Chat 1 09-28-2007 11:34 AM
never lucky! Legacy Posts General Chat 12 07-17-2003 09:08 AM
Out for 2 weeks - Never used microwave once Legacy Posts General Chat 25 07-09-2003 10:12 PM
Top 10 Reasons Why Farm/Ranch Trucks are Never Stolen Legacy Posts Jokes, Stories & Tall Tales 3 02-10-2003 11:31 PM
