Next up a battery. - Page 2 - Fiberglass RV
Old 08-27-2013, 06:44 AM   #21
member
Isle of Wight
Originally Posted by Brian B-P View Post
The area of a circle is pi/4 or 79% of the area of a square
When I was at school (last century) the area of a circle was pi r squared.
My how thing have changed.
WizWid is offline   Reply With Quote
Old 08-27-2013, 07:01 AM   #22
Thomas G.'s Avatar
Just a typo - it is pi * D squared / 4
Old 08-27-2013, 10:46 AM   #23
Brian B-P's Avatar
Things have not changed, and it is not a typo. I wasn't posting the area of a circle, I was referring to the ratio of the area of a circle to the area of a square which with sides equal to the circle diameter.
area of circle: Ac = pi * r² = pi * D² / 4
area of square: As = D²
Ac/As = (pi * D² / 4) / D² = pi/4 = 79%
... just as I said before:
The area of a circle is pi/4 or 79% of the area of a square.
The big difference is the first time I spent about six seconds to work it out in my head, and typing this took much longer.
I suppose it would have been more clear if I said:
The area of a circle is 79% (the value of pi/4) of the area of a square.
Old 08-27-2013, 11:21 AM   #24
Brian B-P's Avatar
Originally Posted by honda03842 View Post
Why would any one buy a battery with 1/3rd less capacity?
... compared to what?
A spiral-cell battery has about one-third less capacity than a flat-plate battery of the same outer package size; there is no meaningful difference in capacity for the same weight. I think in most applications, the package size is not critical.
Old 08-27-2013, 06:06 PM   #25
Raz
Raz's Avatar
Nerd alert
Area of six circles = 6(pi(d^2))/4 = 4.71d^2
Area of a rectangle scribed around six circles (hexagonally packed) is 3.71d x 1.71d = 6.34d^2
(4.71d^2)/(6.34d^2) = .74 or 74%
Irrelevant, just an interesting puzzle.
Edit: if you connect the center of the circles you get an equilateral triangle with of course 60* angles. I used 45*. The corrected value is 72%. Of course this occurred to me in the middle of the night
Old 08-27-2013, 06:14 PM   #26
honda03842's Avatar
Name: Norm and Ginny
Brian,
Are you saying a spiral battery has a higher energy density per unit volume compared to a flooded plate battery?
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
Old 08-27-2013, 06:54 PM   #27
Brian B-P's Avatar
Area of six cylinders = 6(pi(d^2))/4 = 4.71d^2
Area of a rectangle scribed around six cylinders (hexagonally packed) is 3.71d x 1.71d = 6.34d^2
Actually relevant, as one of the Optima models does (or did) stagger the cells (maybe not all the way to hexagonally close packed) to fit one of the BCI formats (sorry, don't remember which one, but the length would have been more than 1.5 times the width).
The pi/4 (79%) factor is the ideal rectangularly arrayed case. Cylindrical (spiral-wound) cells in hexagonal boxes would hit 91%, and real battery case proportions are all going to be worse than that.
The point is just that cylindrical cells don't fit nicely in battery boxes, so the spiral-wound batteries are little bulkier (but not heavier) for the same capacity, or they are lower capacity (and lighter to match) for the same standard box size.
Old 08-27-2013, 06:57 PM   #28
Brian B-P's Avatar
No, about the same energy density per unit volume of working parts and - since both are made of lead and electrolyte - about the same energy density per unit mass. Since the box isn't filled with working parts, the spiral-cell battery has a lower energy density per unit of case volume, but still about the same energy density per unit mass.
Old 08-28-2013, 02:58 AM   #29
Raz
Raz's Avatar
The optima I bought for my tractor Is configured that way which is what got me curious. The only reason I can think of for staggering is to use the same size cylinders to fit a longer or narrower foot print.
battery
Battery Charger on Truck or House Battery? dartz Electrical | Charging, Systems, Solar and Generators 13 06-24-2014 07:59 AM
ParkLiner Battery Monitor and Battery Strap deryk Modifications, Alterations and Updates 23 05-12-2013 12:57 PM
Advice please - how to wire a battery charger battery Steve_N_Janna Electrical | Charging, Systems, Solar and Generators 6 06-17-2012 04:53 PM
Charging Battery and running battery lights when plugged in Nor_Cal_Todd Problem Solving | Owners Helping Owners 2 08-25-2010 01:44 PM
Hooking up boler battery to Tug battery Andy H Problem Solving | Owners Helping Owners 3 08-02-2007 12:59 PM
