No running lights - Fiberglass RV
Old 11-08-2012, 06:48 PM   #1
Lakeville, CT
No running lights
Went to hook up my Scamp to store it for the winter. After hooking up I tested the exterior lights and found nothing working. No running lights, no blinkers, no brake lights. It has been sitting since August when I last towed it and the lights were fine. I use a standard four pin connector and checked that 14 V was coming from connector on the car side. I did put a solar panel on last July but doubt that is related since the lights worked after and the panel connects straight to the controller and on to the battery. Fuse on the wiring harness at the car battery is good. I haven't had a chance to get back out to troubleshoot but I thought I'd ask if anyone had a hunch.
Thanks for any ideas.
biw314 is offline   Reply With Quote
Old 11-08-2012, 06:51 PM   #2
Have you checked the inline fuse near the battery and the one under the rat fur just after the wiring goes into the trailer?
Old 11-08-2012, 07:00 PM   #3
Lakeville, CT
I have not . I looked quickly under the front bunk and didn't see any obvious fuse. Will this fuse under the fur be difficult to find?
Old 11-08-2012, 09:49 PM   #4
William, which layout of trailer do you have? I have a side bath and on mine the fuse was inside the passenger side front hatch right up against the front wall - if you feel around on the rat fur you should be able to feel where all the wires enter the trailer - you may be able to pull open the rat fur to see them all. The inline fuse will be on one of the wires and its just a small glass fuse with tape wrapped around it on mine. Did you find one outside by the battery?
Old 11-08-2012, 11:13 PM   #5
The house battery and associated fuses have nothing to do with the running, tail, and brake lights.
I would look at the negative (ground wire) coming from the tow to the trailer, that's about the only thing that is common with all the those lights. Sometimes in older(really older) trailers they used the frames and hitch to complete the negative side. If somebody rewired to get a charge line they might have substituted a charge line (a wire from the positive to house battery) for the negative wire in connecter and relied on the ball for the negative. Not a good practice.
Old 11-08-2012, 11:15 PM   #6
The four pins should be:
left turn light
right turn light
tail light
Negative.
NOTE The turn signals are the same lights as the brake lights.
Old 11-09-2012, 12:51 AM   #7
William, sorry I miss read your original post and was thinking you had lost everything - Byron is correct. If Byron's suggestion doesnt work out, you may also want to take a look at your connections - corrosion on the plugs , can result in problems with your running lights although usually its just one set of lights that go. Also inside you car you may have a plug in connection with a small electrical modular attached to it. Sorry dont know what its actually called but I know mine had be be replaced after about 3 years - when my running lights stopped functioning, its buried in under all the carpeting in the back of the car.
Old 11-09-2012, 06:44 AM   #8
Thomas G.'s Avatar
Trailer: For Sale Or Rent
Rooms to Let 50 Cents
The most common problem is a poor ground. Try running a separate wire from the tow vehicle ground to the trailer frame.
Old 11-09-2012, 09:26 AM   #9
Borden's Avatar
Name: Borden and Carole
Thomas G. Think you are on to something as we had a ground wire problem on our trailer; ground went to the frame then frame to junction on our rig so ran a new dedicated line from frame attachment area all the way back to the main junction and that worked. We have 7 pin setup and a boler but principle should be the same?
1978 Ontario made Boler
Old 11-09-2012, 09:43 AM   #10
Thomas G.'s Avatar
Yes, the principle is the same. Using the frame as part of the circuit is one of my pet peeves. Corrosion at the junctions is inevitable, yet is so easily avoidable.
Old 11-09-2012, 10:28 AM   #11
Perry J's Avatar
Trailer: 16' Casita
I had an intermittent problem with my left turn signal a couple of weeks ago.
It was driving me crazy as I couldn't find a problem anywhere.
As a last resort I doused both ends of the 7 prong connectors with spray contact cleaner, blew then out with my air compressor and have had no problems since then.
The recepticle has been on my truck for 5 years so I guess it was a little dirty.
Old 11-10-2012, 09:00 AM   #12
Lakeville, CT
Thanks for all the thoughts and suggestions. I'll have time to get in there with a multimeter tomorrow.
Old 11-21-2012, 06:30 PM   #13
Alaska
It might not be your trailer. I tow with a Volvo. The last service did a computer "upgrade" which wiped out all the talk between the car and the trailer. I am in the trailer full time so I was able to trouble shoot it easily. Volvo had to reset the computer and do all kinds of other work before the car and trailer were talking again. Do you have a friend with a tow vehicle? If so suggest you try hooking the trailer to their vechicle and see if you have the same problem.
Alaska Deb is offline   Reply With Quote
Old 11-21-2012, 07:43 PM   #14
FTTRV's Avatar
Trailer: tp
It might be the tow vehicle has a blown fuse. It happened to me this fall. Fuse was blown in tow rig as soon as I replaced it everything worked.
Chuck
LED Running Lights Art VanDelay Problem Solving | Owners Helping Owners 9 08-25-2011 04:09 PM
Running lights Carol Crawley Towing, Hitching, Axles and Running Gear 6 04-12-2008 11:22 PM
Running Lights jrnutpaul Problem Solving | Owners Helping Owners 15 11-20-2006 07:57 PM
new running lights Dan Quinn Problem Solving | Owners Helping Owners 24 05-08-2006 06:06 PM
Running lights Carol Crawley Problem Solving | Owners Helping Owners 0 12-31-1969 07:00 PM
