We had a 16 ft, 2000
Scamp. Unless
Scamp has improved their wiring, you may find that the voltage at the
fridge connections is quite a bit less that 12 volts when on 12V only. Even with a fully charged
battery. Like about 10.5 volts.
The wiring from the
battery goes through the converter, and then to the
fridge. and was of too
light a gauge to carry the load.
I ran a length of 12 gauge wire (with an inline fuse) directly from the
battery to the fridge, thus was able to read over 11 volts at the terminals behind the fridge.
