Optima AGM batteries...Which one? - Fiberglass RV
Old 05-16-2013, 10:21 AM   #1
Trailer: Bigfoot 21 ft
Which Optima AGM battery would work best, blue top or yellow top? I realize that each type comes with different amp hours depending on how much one wishes to spend. That being said which one would work best for a trailer? Also what would be the average minimum amp hours on a battery one should consider.
Thanks
Jim Sinor is offline   Reply With Quote
Old 05-16-2013, 10:41 AM   #2
There's way too many variables to make a positive recommendation.
1. How much time to do you spend camping with no electric hookups?
2. How many battery powered devices to you feel have to use?
3. How do you recharge the battery?
And the list goes on.
I see people using AGM batteries, but I question the reasoning. AGM batteries are great in airplanes, particularly those that go upside down. But for a trailer, or automobile they're pretty expensive when a standard battery will work just as well unless of course you're worried about acid spill when your trailer goes upside down.
What ever type of battery you get AGM or flooded cell a deep cycle battery will perform best for trailer needs.
Old 05-16-2013, 11:04 AM   #3
US
Rv net archive has a lot of good reading for your research, goes a number of years back
http://www.rv.net/forum/index.cfm/fu...d/26472716.cfm
Old 05-16-2013, 01:58 PM   #4
Brian B-P's Avatar
The yellow-tops are their general deep-cycle line; the blue-tops are their marine line (an "M" on the end of the model ID indicates "marine"). Any model starting with "D" (such as "D34") is a deep-cycle battery and thus generally suitable for a travel trailer; the practical difference between blue and yellow is typically little more than the terminal type. You want threaded studs (or lugs with bolt holes), not posts like the battery under the hood of your car, to easily and reliably attach cables which end in ring terminals.
As Byron mentioned, there is no single correct answer for capacity.
Old 05-16-2013, 02:06 PM   #5
Brian B-P's Avatar
I agree, but it isn't just inversion - acceleration and vibration are better handled by AGM as welll... although a trailer should still be well-served by a conventional flooded battery.
I think some people are going with AGM because either:
  • they are locating the battery inside the trailer body and they incorrectly believe that an AGM battery does not require venting; or,
  • they want to eliminate the need for maintenance access.
Old 05-16-2013, 02:36 PM   #6
There's another reason people want to use AGM batteries, somebody said AGM batteries are the best because they're the most expensive. My flooded cell battery lasted about the same amount of time as and as AGM battery. The extra cost went into the gas tank to do more camping.
Old 05-16-2013, 06:30 PM   #7
Raz
Raz's Avatar
Vermont
I went with an AGM for the trailer because I thought the benefits were worth the extra money. This is year six. We'll see how it goes. When I needed a battery for my tractor I also went with an AGM because it was sealed and because of the low self discharge. The tractor can sit months without use. The yellow top optima was recommended. Raz
Old 05-16-2013, 08:13 PM   #8
I was led to believe that AGM batteries can be recharged many more cycles than a conventional battery. Also that they can be discharged to a lower level with no harm done than a conventional lead acid battery.
Is this correct or not?
Old 05-16-2013, 09:39 PM   #9
Brian B-P's Avatar
That makes sense to me.
Old 05-17-2013, 12:39 AM   #10
Sometimes the cost vs value don't quite add, at to me. AGM batteries are about twice the price of a flooded cell battery. For every AGM battery, I can buy two flooded cell batteries.
Optima Blue top Group 24 size is only 55 amp hour. Flooded cell Group 24 is between 70 and 80 amp hour. So looks to me like twice the cost for around 25% less capacity.
What ever floats your boat.
Old 05-17-2013, 03:50 AM   #11
Raz
Raz's Avatar
Vermont
I bought the Lifeline GPL 24 T when the battery on our first trailer died in 3 years. I'm still using it. It was a little over $200 or almost 3x the Walmart battery price at the time (2007). They claim up to 1000 charge/discharge cycles. We camp less than 50 days/year and use about 5-10 Ahr a night. LED lights. A small fan I modified to use less about 1/2 amp and the water pump. Because of parasitic loads, I noticed any time I connected the battery, there was a small spark. The sealed battery is safer in my opinion. If I break even I'll be happy. It's about the closest I come to gambling. Raz
http://www.lifelinebatteries.com/rvd...ebatteries.php
Old 05-17-2013, 10:54 AM   #12
Trailer: 2008 Casita 17 SD
Another big issue with using AGM batteries has to do with what kind of charger you are using to charge and maintain it. Standard wet-cell batteries, besides being less expensive, are not as fickle nor prone to problems of overcharging. AGM batteries do not possess the capacity that wet-cell batteries have to tolerating being overcharged. Yes, overcharging is not a good thing irregardless of the type of battery, it's just AGM's will crap out on you faster if overcharged. Wet-cells are a bit more forgiving in this regard. Which brings us to the problem with most trailers out there, they generally have single stage chargers installed in their converters, and this is all because they are cheaper for the trailer manufacturers to install, (it's all about profitability.) They come equipped with single stage chargers, (aka "dumb chargers",) which do not properly regulate and adjust power requirements as the battery approaches a state of full charge. They just keep pumping charging current into the battery at the one and only rate they are capable of putting out. So, unless you are planning to upgrade your converter to one capable of "smart charging", (i.e. a good 3 or 4 stage charger,) you are just wasting your money on an AGM. I agree with Byron in that the best battery for an rv or trailer is still a standard wet-cell type. I'm sure others will feel compelled to tell of the great success they have using AGM's, but why pay more for something you don't really need?
Old 05-18-2013, 01:30 AM   #13
Trailer: Casita 2001 spirit
Gee, my trailer is a rollover - quess I should have gotten that AGM battery for upside down use.
partslady9 is offline   Reply With Quote
Old 05-18-2013, 02:45 AM   #14
Jared J's Avatar
Trailer: 1984 19' scamp
Kansas
I used to run optimas. The old ones worked great for years. The newer ones…well, I ran through 3 of them in 4 years. I stuck a Walmart battery in, went for six years. Another had exide orbitals, killed 2 of them in. 2 years. I threw a cheap parts store battery in it in 2006, still works.
I used to like optimas, now I wouldn't touch them.
Parkliner Electrical System & AGM Battery Charging-Maintaining accrete Electrical | Charging, Systems, Solar and Generators 15 05-16-2013 06:03 PM
AGM Battery ? jck Care and Feeding of Molded Fiberglass Trailers 29 12-28-2012 04:46 PM
Got a 2nd battery, AGM, 2 questions?! dylanear Modifications, Alterations and Updates 13 07-28-2012 02:47 PM
Optima Batteries George Cathcart Problem Solving | Owners Helping Owners 3 07-19-2009 11:21 PM
Interior mounting of Optima batteries... Ken Vernon Problem Solving | Owners Helping Owners 16 10-20-2008 04:31 PM
