overcharging risk with converters? - Fiberglass RV
Old 03-27-2018, 04:54 PM   #1
Trailer: scamp 16
In our 2009 Scamp is a charger converter that looks to be made by the Wizard brand company. I think the series is 9100 or thereabouts from that time. Is there a risk of overcharging ones deep cycle battery when driving a long distance for several hours? Does one disconnect their battery after a few hours of driving to protect it or do these charger converters do a good job of not overcharging eventually? thanks
hiker22 is offline   Reply With Quote
Old 03-27-2018, 06:19 PM   #2
The converter is NOT running while towing. It's only on when the trailer is plugged into shore power.
Byron Kinnaman is online now   Reply With Quote
Old 03-27-2018, 06:21 PM   #3
Convert == change something to something else.
In case of RV's converters it changes 120VAC to something around 13.8VDC. (13.8VDC is tow vehicle voltage)
Old 03-27-2018, 07:07 PM   #4
rbryan's Avatar
Arkansas
Right, because there's nothing to convert.
Old 03-27-2018, 07:23 PM   #5
The question is confusing so I understand why previously replies might have missed the mark. As I understand it, the question is "will your R/V battery be over charged while traveling"?
It's true that the converter is not in use unless and until you are connected to 120 VAC shore power. Therefore, the information about the converter make and model has no bearing on that question.
So the only source of charging while you are traveling the the tow vehicle, or more specifically, the tow vehicle's alternator. It gets a little involved but as I understand it, it is possible to over charge the trailer battery from the tow vehicle, but in practice because of losses in the wiring, the relatively short time the vehicle is charging, etc, the likelihood of having a problem form over charging from the tow vehicle is very slight.
By the way, I am going to guess that you saw the Charge Wizard option connected to a Progressive Dynamics 9100 converter (in effect, an enhanced 9100 model). The charge wizard provides better battery charging for the 9100 model converter, and helps to prevent over charging, but again.. only when using shore power
Old 03-28-2018, 04:21 AM   #6
Steve L.'s Avatar
Trailer: 2003 Casita 16' SD
As I read the OP's last sentence it does seem to lead a reader to believe the OP thinks the converter is running while towing. As stated, the converter is not charging while driving. In any event the answer to both his questions is "no". The alternator is seeing some kluged together common voltage of the tow battery and the trailer battery and it (the alternator) reduces the charging depending on the voltage it measures. If it didn't, that would be bad news for all our tow vehicle batteries, towing or not.
Without adult supervision...
Also,
Old 03-28-2018, 02:10 PM   #7
Name: Wayne & Barbara
Trailer: Parkliner
Iowa
As mentioned by others, it is your TV's alternator that charges both batteries while on the road. they are connected in parallel, so look like one big 12 volt battery to the system. The voltage regulator controls the maximum output.
Old 03-28-2018, 02:45 PM   #8
BC
We always install a second wire from the tow V's batt to the trailer batt, this helps overcome the slow charging by the TV, (I like TV thanks for saving me typing time!!)
The reason for the slow charge is that the TV's alternator is responding to the state of charge in the TV, which is almost always fully charged, so what you get at the trailer is a bleed off from the TV batt. A batt isolator will help.
Many times I leave the batts connected, so that the vehicle batt is discharged to the same level as the trailer, that way the alternator sees a lower state of charge and will speed up the charging process accordingly. If you try that at home, be very careful to understand your power usage so that you do not take the vehicle battery too low to start the eng.
We're lost but we're making good time.
Eggcentric is offline   Reply With Quote
Old 03-28-2018, 02:47 PM   #9
you are right tony I am sure the alternator only looks at the tv battery charge and once it is charged it quits although maybe the other battery might come into play some!
bob
Old 03-28-2018, 02:55 PM   #10
BC
Should have mentioned that if you do put in a dedicated charging circuit, be sure to fuse each end of the positive + wire, as both the TV and trailer batts will energize the wire if it goes to ground.
Old 03-28-2018, 03:05 PM   #11
Trailer: Parkliner
Iowa
Our installer did run a heavier wire from the TV battery to the trailer, one of the 7 pins. It has a fuse too. But, if you're not hooked up to shore power and leave them plugged in for too long, you will discharge the TV battery and may not be able to start your engine.
There is a device for sequentially charging two batteries instead of simultaneously.
Old 03-28-2018, 03:58 PM   #12
To the point answers-
While traveling:
No, you will not over charge your onboard battery while traveling.
On electricity:
If you have one of these devices plugged IN to your converter, then you can charge on electricity indefinitely: (click on link)
https://www.progressivedyn.com/rv/ch...charge-wizard/
Still on electricity:
IF you do NOT have one of these "Wizard"s connected to your converter, then YES, you can over charge and it will eventually destroy your battery!
Charging the RV battery, overcharging tow vehicle 4suresure Care and Feeding of Molded Fiberglass Trailers 2 07-22-2017 07:58 PM
Tow vehicle overcharging Scamp battery John Linck Electrical | Charging, Systems, Solar and Generators 20 10-08-2013 07:22 PM
Risk adverse automakers ronsmith100 Towing, Hitching, Axles and Running Gear 16 02-26-2009 12:09 PM
Risk of Towing Beyond the Limits Pete Dumbleton Towing, Hitching, Axles and Running Gear 6 05-26-2008 06:39 PM
Risk of Towing Beyond the Limits Pete Dumbleton General Chat 0 01-01-1970 12:00 AM
