Parkliner Electrical System & AGM Battery Charging-Maintaining - Page 2 - Fiberglass RV
Old 05-16-2013, 05:47 PM   #15
mrscottyg's Avatar
Trailer: 2012 ParkLiner
From the Optima battery User's Guide:
An Optima is an AGM battery, not a gel battery or regular flooded acid battery.
Most modern battery chargers, including OPTIMA Chargers, have a built-in AGM charge setting, which should be used for your Optima. If purchasing a new battery charger, make sure it has AGM compatibility or a separate AGM setting. Do not use gel or gel/AGM settings, as this will not fully charge an Optima and can damage it over time.
Based on this, Thom, I would recommend NOT putting the converter into gel mode.
mrscottyg is offline   Reply With Quote
Old 05-16-2013, 06:03 PM   #16
accrete's Avatar
Trailer: Chevy AWD Van Conversion
Astoria Oregon
Yuppers...& thx for the info... I had no intention to switch as I had previously stated... I know the difference between Gel @ AGM from my Ham shack builds.
Blogging from the WET! Coast of Oregon
Bed, Bath, & Beyond...
2010 Chevy Express 1500 AWD Van
Archive: Parkliner #35 build thread
accrete is offline   Reply With Quote
battery, electrical, parkliner
ParkLiner Battery Monitor and Battery Strap deryk Modifications, Alterations and Updates 23 05-12-2013 12:57 PM
AGM Battery ? jck Care and Feeding of Molded Fiberglass Trailers 29 12-28-2012 03:46 PM
Got a 2nd battery, AGM, 2 questions?! dylanear Modifications, Alterations and Updates 13 07-28-2012 02:47 PM
Charging Battery and running battery lights when plugged in Nor_Cal_Todd Problem Solving | Owners Helping Owners 2 08-25-2010 01:44 PM
Electrical System Barbara Gardin Electrical | Charging, Systems, Solar and Generators 2 04-18-2006 03:37 PM
