phantom battery draw question - Page 3 - Fiberglass RV
Old 02-20-2015, 04:39 PM   #29
Raz
Raz's Avatar
Vermont
Originally Posted by steve dunham View Post
RAZ ,it appears to me you need to install a branch circuit breaker on the buss.
Then run a conductor from the load side of the breaker to the 4 hole buss on the right side . This would supply power to the AC side of the converter . Why they did not install a 15 amp breaker to feed the converter at the factory is a mystery to me
Just to set things strait my converter is fine.
Suz asked the question in post 12.
Bob commented:Apparently the confusion here is that there is an 4-5 terminal buss bar on the right side of the box labeled something like "120VAC HOT". I asked PD about this buss and was told that it was required for Canadian (CSA?) approval, that the incoming hot lead had to go there first, before going to the bottom feed on the main breaker. At least that's what they told me. It's not used in U.S. installations, but being there and being labeled is a bit confusing..
I responded to him.
As I said earlier, PD's instructions are a little brief.
Old 02-20-2015, 05:01 PM   #30
Trailer: Casita 17 ft DLX SD
Originally Posted by Bob Miller View Post
The wire shown running from the converter to the small buss bar is a broken line, suggesting that is one way to connect it, it does not have to be wired that way. But if you did, you would also have to energize that buss bar yourself by installing a load breaker and connecting that to the small buss as well. As shown, that bar is DEAD.
Connecting the converter power IN to it's own breaker on the main buss is the usual and customary of installing them. I have installed at least 7 and never used that small buss.
If it was me ,I would connect the AC wire from the converter directly to the load terminal of a 15 amp breaker and just leave the small 4 hole buss on the right side dead. The only advantage I see in terminatin the incoming line conductor at the 4 hole buss is that you could disconnect the hot wire that feeds the main breaker at the buss .What you gain by this arrangement is not clear to me
steve dunham is online now   Reply With Quote
battery
Power draw from tv battery when turned off Wallo Towing, Hitching, Axles and Running Gear 39 06-08-2013 11:36 AM
amp draw Dan B Problem Solving | Owners Helping Owners 18 05-30-2008 07:50 AM
Any Draw On my Battery? Gerry Problem Solving | Owners Helping Owners 8 08-17-2007 04:03 PM
Low amp draw DC fluorescant light Joe Z Modifications, Alterations and Updates 6 07-08-2007 04:33 PM
fridge draw colin k Problem Solving | Owners Helping Owners 24 03-30-2006 09:03 PM
