Planning my solar layout - Will this work? - Fiberglass RV
Old 03-30-2013, 09:30 AM   #1
Kevin K's Avatar
Trailer: 17' Casita
Mpls,Minnesota
I have a portable solar panel for my trailer for outside.
I plan on putting the solar panel, inside the trailer by a window when traveling, to collect the sun's rays. I want to use a wall receptacle inside the trailer just for the solar panel plug in.
Will this setup work? (see photo)
Name:	<a title=solar a.JPG Views: 49 Size: 58.2 KB ID: 56813" style="margin: 2px" />
Old 03-30-2013, 10:42 AM   #2
Thomas G.'s Avatar
Trailer: For Sale Or Rent
Rooms to Let 50 Cents
From a wiring standpoint it will work. I personally don't like to use 110 volt fixtures for other than their intended purposes. You don't want some innocent plugging your solar panel into a live wall socket.
If I was doing this I would use this style plug:
Amazon.com: CES 10 Gauge 2 Pin Quick Disconnect Harness: Automotive
Old 03-30-2013, 11:19 AM   #3
Joe MacDonald's Avatar
the male plug on the panel could short out if the panel was generating electricity,
I would make sure to follow general rules like AC plugs are for AC, find different ones for DC.
Anything that is live or generating power should be a female plug to prevent shock or arc.
Old 03-30-2013, 04:40 PM   #4
Trailer: '77 Scamp
I see you have a fuse just before the battery. I'll be installing my solar soon and while shopping for parts, I didn't know what size fuse I should put in for a 100w solar panel and 30A MPPT controller. Thoughts???
Otters is offline   Reply With Quote
Old 03-30-2013, 04:53 PM   #5
GMike A's Avatar
I totally agree with Tom for connections. Also I would recommend or consider Anderson Pole connectors. They are configurable and will handle all the current you need as well as being able to polarize them. Just a thought.
Mike
Mike
K5NAN
"Miss Adventures"
If you Rest, You Rust
Old 03-30-2013, 04:56 PM   #6
Dave Storey's Avatar
Name: Dave & Elinor
Trailer: Trillium 4500
Hi here are few vids on solar panel install etc to give you some ideas \
Have fun
Dave and Elinor
Dave Storey is offline   Reply With Quote
Old 03-30-2013, 05:31 PM   #7
GMike A's Avatar
Thanks for the videos and again to echo Tom to use 110 or 220vac connectors for anything other then their intended purpose is not a good idea. I'm sure you will get tired of hearing it. The next future owner might not understand the intent. The connectors that Tom showed are great just remember to always keep the + polarity hidden inside the connector shell and not the male sticking out. All my Ham equipment in my house and car are wired with the Andersons as an FYI.
Mike
K5NAN
"Miss Adventures"
Old 03-30-2013, 06:07 PM   #8
rabbit's Avatar
Trailer: '98 BURRO 17WB
Delaware
Good point about making the positive lead shielded on the flat connectors. Unfortunately, hookup to the battery with only one set means that there's an exposed hot contact coming from either the panel or the battery. If you used an extension cord, you'd have the hot side shielded on both; + would be the exposed contact on both ends of the extension. Even that isn't the best situation, is it? If you go with the flat connnectors get the ones with 10 gauge conductors shown by Tom. A lot of these are 16awg and create a resistance bottleneck. If you go with the Anderson pole connectors, be aware that the contacts are difficult to crimp correctly without the proprietary luggers from Anderson (or equivalent), none of which are inexpensive for a one time job.
jack
Old 03-30-2013, 06:12 PM   #9
Trailer: Fiber Stream
My solar panels came from the factory with these connectors installed.
Old 03-30-2013, 06:33 PM   #10
GMike A's Avatar
How do you like that solar kit Fred? I see they are on sale now for either 129 or 149. Yes you are right Anderson power poles are not cheap but good. I get my Anderson's here at about half price. Andy Crimp Pro - PowerPoles, Tools - Powerpole Tools - Andy Crimp Pro - High Sierra with over 625 Products
Mike
K5NAN
"Miss Adventures"
Old 03-30-2013, 06:53 PM   #11
Cool
I like it well enough to own 2 of them. One is permanently mounted on the roof of my workshop. It keeps a portable Group 27 battery topped up at home between camping trips. I use the battery when boondocking to run a 300 watt inverter.
The other I carry in a factory reject ABS Electric Guitar Case to use during boondocking trips.
ID:	56841 Click image for larger version
Old 03-31-2013, 06:10 AM   #12
Ron F's Avatar
Trailer: Eggless for now.
Formerly NH, now full timing
I doubt that mounting the panel inside near a window will provide enough power to be worth the wiring and effort. Besides, you can charge the battery with the 12v connection to you tug. Why not just keep your battery charged from the tow vehicle and connect your panel outside when you're parked. Here's a neat way to make the connection outside: Making portable solar panels less annoying .
Old 04-01-2013, 07:17 AM   #13
Raz
Raz's Avatar
Vermont
I agree with Ron, not worth the effort. Raz
Old 04-01-2013, 07:19 AM   #14
Thomas G.'s Avatar
I just soldered my Anderson connections. You can buy Anderson connectors on eBay, though they may be overkill for this application.
solar
Looking for Scamp 16, Layout 6 guerillabill Wanted: Molded Fiberglass Travel Trailers 3 11-29-2012 03:09 PM
the new (and hopefully final) layout cyndi H Fulltiming in a Molded Fiberglass Trailer 20 09-18-2012 11:30 AM
Looking for a Scamp 19' Deluxe, Layout A potatowire Wanted: Molded Fiberglass Travel Trailers 2 08-06-2012 01:48 PM
Scamp Trailer layout question Kevin K General Chat 17 06-25-2011 09:28 PM
