Please check my (electrical) math - Fiberglass RV
Closed Thread
Old 05-03-2018, 09:32 AM   #1
Background - I am adding an electrical outlet to my 1997 Scamp 13 in conjunction with installing a removable window AC unit. I noticed that the 3-way Dometic refrigerator is wired in series with the existing 120v outlet next to the sink and wondered if this could cause a problem.
My Dometic owner's manual states that the heating element is rated at 125 watts. Assuming single phase AC power, using a power factor of 1, that works out to 1.04 amps (125/120). Which seems like a very low number for a refrigerator?
On 12 volts DC, the draw is 10.4 amps.
If the fridge really is drawing less than 2 amps, I'll just leave thing the way they are. I'm a new Scamp owner and have only taken one 6-week trip in this unit where I had several things plugged into the 120 v outlet via an outlet strip - fan, computer, table lamp, computer speakers, phone charger. No problems experienced with hot-feeling wires, etc.
Thanks.
nigeleccleston is offline
Old 05-03-2018, 09:36 AM   #2
John in Michigan's Avatar
Yes, 1 amp draw at 110 volts AC (or 10 amps at 12 volts DC) sounds about right. That's what my Dometic 3 way refrigerator draws.
Trillium 4500 Journal
http://www.fiberglassrv.com/forums/f...nal-81345.html
John in Michigan is offline
Old 05-03-2018, 10:37 AM   #3
Civilguy's Avatar
Puget Sound, WA
Nigel,
Our Casita had a 4 cu ft Dometic RM2454. It drew 1.5 amps on 120VAC.
- "I am not here for grammer lesson's" -
Civilguy is offline
Old 05-03-2018, 10:50 AM   #4
John in Santa Cruz's Avatar
Trailer: 2014 Escape 21, 2002 Ford F250 7.3 Diesel 4x4
surely, you mean the outlet is wired in PARALLEL.
and yeah, 125 watts sounds about right for an absorbption fridge. 10 amps at 12V is the same 120 watts as 1 amp at 120V.
John in Santa Cruz is online now
Old 05-03-2018, 01:53 PM   #5
David Tilston's Avatar
Not that it matters, but if it was wired in series, then it would only work when something was plugged into the the other outlet, and that something would have to draw lots of power, (low resistance). A heater maybe. Neither would work as designed as they would be sharing the total voltage.
The fridge would then work best if the other plug was a dead short.
David Tilston is offline
Old 05-03-2018, 02:01 PM   #6
CarlD's Avatar
Trailer: LiL Hauley
Syracuse, NY
Depending on the BTU rating of the AC unit, you may or may not be able to run it on the same circuit as the fridge. A 5000 BTU AC is probably in the 6-7 amp load range (check the specifications for your AC unit). Starting should not be an issue as a typical circuit breaker is a thermal type designed to take a momentary overload, however, bear in mind that they are rated for 80% of full load rating for long delay times. Minimum circuit breaker size for household wire is 15 amps. 15 amps times .8 is 12 amps which is the maximum load. That being said, you should have no issue running the fridge and a 5000 BTU AC unit on the same circuit. A 8000 BTU unit puts you in the questionable range. Hope this helps.
Every day is a Saturday
CarlD is offline
Old 05-03-2018, 07:10 PM   #7
Well .. in series means one after another in a daisy chain fashion, and the hot is wired in series, the neutral is wired in series, and the ground is wired in series.
Confused yet?
If so then follow the flow of electrons.. they don't have to go along the daisy chain.
gordon2 is offline
Old 05-04-2018, 12:35 AM   #8
Confused yet?
If so then follow the flow of electons.. they dont have to go along the daisy chain.
In all 120VAC wiring the neutral line go to all neutral terminals and the hot line goes to all hot lines. The safety goes all the green terminals. No SERIES to it, all Parallel.
Byron Kinnaman is offline
Old 05-04-2018, 12:40 AM   #9
Thanks.
Your math is correct. The only error I see is the term series. All 120 vac outlets and devices are connected in parallel. Your's are too.
As for all the stuff you have connected to only outlet. None of them draw much current. So every things good.
Old 05-04-2018, 06:45 AM   #10
Alas, you missed my point. It is of course a parallel circuit, but there is a "series to it" and this can cause confusion. The neutral wires are connected in a series, one after another. Same for the hot and the ground. So my point was that this is a reason why someone might get the terms mixed-up. If one understands this point of confusion, one is better able to explain the terminology.
My other point was if someone is not sure to call it a series or parallel circuit...
...then follow the flow of electrons.. ...
In series circuit there is only one route and they have to go along the entire length of the daisy chain, though the wires and loads both. In a parallel circuit, there are parallel routes.
gordon2 is offline
Old 05-04-2018, 08:54 AM   #11
OK, thanks for the advice and for correcting my series-parallel mistake. I'm leaving the fridge wired as is, and adding an extra breaker wired to a new outlet in the wall of the dinette bench. I'll plug the removable window unit into that. And FYI, the AC will be held in place by one of these Towing 16' with 4 cylinder
Closed Thread
electrical
'89 Bigfoot 19-B weight and bad math? hogzilla Problem Solving | Owners Helping Owners 9 04-26-2014 01:12 PM
OK you math wizards--I dare ya! Vickie B. Problem Solving | Owners Helping Owners 15 09-26-2009 05:15 PM
Towing Stuf and Some Math Pete Dumbleton Towing, Hitching, Axles and Running Gear 4 03-14-2009 06:33 AM
doing the math... squeezing inches Michael M Problem Solving | Owners Helping Owners 5 11-16-2007 08:41 AM
Math and Stingers Sharon Herman Problem Solving | Owners Helping Owners 2 05-04-2007 05:04 PM
