Power center or fuse box and charger - Fiberglass RV
Old 09-27-2017, 09:27 AM   #1
I'm not interested in having any 110V at all in my trailer. I just want 12V to run my pertier element cooler, lights, fan, and USB outlets. WOuld there be any benefit to installing a power center like the WFCO WF8712PB Black 12 Amps Power Center (https://www.amazon.com/WFCO-WF-8725-...RSJR6V16J&th=1) over simply connecting a battery charger to the battery when shore power is available, and wiring all 12V behind a Blue Sea Systems ST Blade ATO/ATC Fuse Blocks
(https://www.amazon.com/gp/product/B0...f_rd_i=desktop) directly connected to the battery?
jeroen is offline   Reply With Quote
Old 09-27-2017, 01:01 PM   #2
John in Michigan's Avatar
Trailer: 1978 Trillium 4500
Nope, really no benefit to using the WFCO WF8712PB unit if you are only running 12vdc. The WFCO unit is designed to take in 110vac shore power, includes 110vac circuit breaker slots and a 110vac to 12vdc converter, none of which you would be using.
Just install a 12vdc fuse panel such as the Blue Sea Systems unit that you cited.
Trillium 4500 Journal
http://www.fiberglassrv.com/forums/f...nal-81345.html
Old 09-27-2017, 08:19 PM   #3
Trailer: Scamp (16 Std Layout 4) with '15 Toyota Sienna LE Tug
I think I have to agree with John, but I feel obligated to mention that having 120 VAC in camper can be a big plus and many people would not have a home (even a temporary one) without it. If I recall correctly, you are doing a complete rebuild. If that is the case, then even if you don't foresee the need for AC and a on-board converter/charger, it might be a good to give some serious thought to the possibility that you might want it in the future, or might sell the camper to someone who would insist on it. It might be a good idea to at least pre-wire it for AC and make the future installation of a converter /power center easier.
Old 09-28-2017, 05:02 PM   #4
If your buying all of the electrical components and a new state of the art battery charger you are very close to the cost of a new power center so why limit yourself. Charging a battery and charging a battery and pulling additional loads through a battery charger are 2 different things. Some chargers may not like that task.
I like blue Seas stuff but it isn't cheap. My Scamp came with a 120 volt AC system and a 12 volt Dc system. There was no load center or 12 volt conversion or charging. First thing I did was rip it out and put in a progressive Dynamics system just so I didn't have to deal with battery issues. At home I just plug it in and forget about it. It does a much better job maintaining the battery than I am willing to do fiddling with battery chargers.
stevebaz is online now   Reply With Quote
Old 09-29-2017, 12:07 PM   #5
I came to the same conclusion about cost. It's pretty much the same cost.
Should I go for a $145 Progressive Dynamics PD4135KV Inteli-Power Converter with Built-in Charge Wizard (https://www.amazon.com/Progressive-D...ssive+dynamics) or will a $105 WFCO WF-8735-P Black 30 Amp Power Center (https://www.amazon.com/dp/B004LF14Q4...506704697&sr=1) do the same?
Old 09-29-2017, 12:24 PM   #6
Trailer: 1980 18' Sunrader Motorhome and 1971 Trailswest Campster
There is some benefit if you are running any items that are voltage range sensitive. The converter units do regulate the output.
Old 09-29-2017, 06:21 PM   #7
I don't know about the panels you are checking out I used the PD4045 in my Scamp. When I bought mine I bought it through best converters.
Old 09-29-2017, 07:09 PM   #8
Buggeee's Avatar
Trailer: Playpac
OH
I'm a fan of the Progressive Dynamics because of the 4th stage. When it senses long term storage it will hit the battery with a higher voltage for 15 minutes every third day or so. That shakes sulfates off the lead plates so they don't get crusty from the constant low voltage float charge in storage.
I use a separate converter (aka charger) - a Progressive Dynamics with the features also provided by the one you link to, and a separate12v circuit breaker panel (serves like the fuse panel you mentioned at first) and a separate 120vac circuit breaker panel. So I'm not familiar with the all-in-one model's other features. I play with arrangements in my campers so these separate pieces allow for flexibility down the road.
If you are going to be using a lot of 12v accessories, or more than one battery, consider a higher amp converter. Another fifty bucks will get you a 60 or 70 amp Progressive Dynamics smart charger. But then you'll still have to add a fuse panel for your 12-volt and a circuit breaker panel for your AC. This all in one unit you linked to has a 30 amp converter but it seems like a very affordable way to handle it all and a simple installation.
Buggeee is offline   Reply With Quote
Old 09-29-2017, 11:18 PM   #9
Carl V's Avatar
Trailer: 1981 Trillium 5500
Quebec
Should I go for a $145 Progressive Dynamics PD4135KV Inteli-Power Converter with Built-in Charge Wizard ...
The PD4135 is what I installed in my Trillium last year.
I had an issue with the fan running continuously at low speed even when there wasn't any load on the converter section. Contacted PD, they said this was not normal, and they quickly sent me a replacement converter section, free of charge. Great customer service!
New unit works nicely.
Be aware you will need 120V circuit breakers as they are not included with the converter, and you will need to add a common bus bar for the 12V negatives as there is none in the converter. Otherwise, pretty straightforward to wire.
Carl V is online now   Reply With Quote
Old 09-30-2017, 07:20 AM   #10
Buggeee's Avatar
Trailer: Playpac
OH
Dude, it sounds like you're halfway to it true 12 volt fuse panel and will need a separate 120 volt panel anyway. Not stalking you but I did see some of your other threads and it seems that you plan on working this 12-volt system for more than just lights and a water pump. If you're going to be running some form of refrigerator off the 12 volt system and powering various devices with your 12-volt outlets and, otherwise enjoying the fruits that electrons have to offer us, my guess is you're going to be running multiple batteries at some point.
By all means start off with whatever you start off with in terms of battery because they can be expensive but have one eye on the future since you're keeping this camper and have an interest in this electric life.
Even if you're plugged into shore power, if you're running refrigeration off of 12 volts, along with all this other stuff, I wonder if it's possible to deplete the battery a bit if your converter isn't up to the task. In any event, if you do end up adding batteries and want to charge a multiple battery bank, you will be much happier with a stronger converter than the 30 amp standard.
Here is a link to the progressive Dynamics 9200 series chargers. I would definitely stay with the charge wizard chargers because that has the battery management system built into it.
https://www.progressivedyn.com/rv/po...er-converters/
As mentioned before I use the 60 amp because that's what I happen to get at the time, although it was overkill for what I originally had. Now it seems you can get a 70 amp for the same price as a 60 amp. I'm really glad I did too because I ended up adding batteries and I've actually carried that converter with me with different campers, swapping in an inexpensive one and standard RV battery when I would sell off the old camper. I also use the remote pendant which is just a button with a wire that connects to the charger that allows you do force it into whichever charging stage you want if you choose to do that it's only 25 bucks and a neat toy.
Have fun. It's a deep Rabbit Hole you just fell into! :-)
Old 09-30-2017, 08:18 AM   #11
So these amp ratings; that's the maximum it can pull right? Even the small 12 amp rated WFCO 8712 has a label that says panel input 110V 30A. I have a 15 amp outlet in my garage, so is that 30amp the max that panel will pull if a put a 30 amp main breaker in it? Should I put a 15 amp main breaker in it instead?
Old 09-30-2017, 09:06 AM   #12
depends...
if you're going to pack a hair dryer, toaster oven, blender and an electric coffee maker in your trailer...by all means get a converter
if not, you don't really need one...going all 12V is a little more "work" than just buying and installing a power center that comes with a built in converter (and a cooling fan)...
I agree that the cost of both options is about the same....if you're going to the "all 12V" option, you'll want a charger that can double as a power supply (in the specs) of an amperage that is high enough to keep up with your maximum potential load....they are not cheap but are very "smart"...as a bonus, mine is double insulated and doesn't need/have a fan.
I reused the AC panel that was in my original power center... I still have breakers inside my trailer (plugged in, I could run that hair dryer)..... I don't have an opinion or knowledge about just running an extension cord (a good one) to your trailer...
I've been "all 12V" for 3 years now...it works
I'm old enough to remember when a 60A service was the norm for a HOUSE ! (my present house has 100A)....running 60A into a one hundred square foot fiberglass box seems really strange to me....unless it was used as an equipment trailer for a rock band and they used it to plug all that equipment into at outdoor concerts
Franswa is online now   Reply With Quote
Old 09-30-2017, 09:07 AM   #13
Buggeee's Avatar
Trailer: Playpac
OH
The amp ratings of the coverters are referring to their output capabilities on the 12v side.
The input ratings you mention are the maximum the unit can withstand and/or might pull in from the shore power. If your house is a 15 amp outlet on a 15 amp breaker then your house circuit breaker will trip before your unit pulls anything more than 15 amps. Most RV hookups when you are camping offer 30 amp hookup (and sometimes 50). Your unit can make use of that 30 amp supply if it is available. I suppose it might trip the house circuit breaker if it really asks for more than 15 amps from it. At home I plug mine into a 15 amps circuit and I have never tripped it.
Old 09-30-2017, 09:11 AM   #14
clarity...
in the first line.....by all means get a converter
should have read : by all means get a full on power center with converter
How can you make a dumb converter/charger a smart charger? Timber Wolf Electrical | Charging, Systems, Solar and Generators 10 03-09-2016 12:11 PM
WFCO Ultra III 30 amp Power Center w/12 amp converter/charger bpfick Parts: Buy | Sell | Trade 1 11-10-2015 06:49 PM
» Virginia Campgrounds
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
