Power inverter on 1980 play mor 2 - Fiberglass RV
Old 04-18-2015, 07:25 AM   #1
Trailer: 1980 Play Mor II
I have a question about the power inverter on 1980 play mor 2. It is the one that came with camper.Does it have a battery charger built-in it? Does anyone know if it will charge the battery while being plugged into a outlet?
Sent from my SM-N900V using Fiberglass RV mobile app
the_real_elvis is offline   Reply With Quote
Old 04-18-2015, 07:56 AM   #2
I suspect you have a converter, not an inverter. An inverter in an RV takes 12 volt DC power and turns it into 120 volt AC. A converter takes 120 volt AC and converts it to DC. Your equipment most likely will charge your battery, but many of the older units are not very efficient. If you have a new battery an charge in incorrectly you will ruin the battery. The technology we have today is much better than it was 35 years ago.
Old 04-18-2015, 08:12 AM   #3
After 25 years it's only a guess as to what you have and what it will do. Look at it and post the make and model number and you will get some feedback.
Old 04-20-2015, 11:30 AM   #4
Sorry for not posting that info. I have a B-W manufacturer 6015 power system. I was told that I would have to replace it. Do you know what I can replace it with? Thanks
Old 04-20-2015, 11:33 AM   #5
As I oft mention, the Progressive Dynamics PD-4045 is the perfect power center replacement for FGRV. It incorporates an ac distribution/circuit breaker section, a 45 amp converter with 12 fuse positions, and a 3 stage smart charger. I have installed about 7 of them without a single problem or complaint.
They can be found on-line for less than $175.00.
Old 04-20-2015, 01:08 PM   #6
Raff's Avatar
Gotta agree. PD4045, put one in my Boler. All wiring to one location and it works perfectly.
Raff is offline   Reply With Quote
Old 04-20-2015, 01:28 PM   #7
Thanks for all your help.
Old 04-26-2015, 08:29 PM   #8
I was wondering if you know what website to go to so could get one for that price? Where did you get the one's that you insta8? Thanks for your help.
Old 04-26-2015, 09:07 PM   #9
PD-4045 Sources
First: Try Frank Bear at teardroptrailerparts.com. If it's not on the website, call them and ask for Frank, and tell him what you want.
Also Vintage Trailer Supply - parts and supplies for vintage travel trailers and campers! is currently showing them for $176.00
Old 04-27-2015, 01:31 PM   #10
Thanks
1980 scamp play mor 2 the_real_elvis Problem Solving | Owners Helping Owners 5 04-07-2015 08:57 AM
AD Unavailable - Can I just say, Sweeeeet! Play-Mor $ Robin G Classified Archives 9 04-27-2009 04:48 PM
Play-Mor II Rebuild. Need guidance Geron Problem Solving | Owners Helping Owners 6 06-06-2008 04:18 PM
Restoring a Play-Mor II ('87 I think) Geron Modifications, Alterations and Updates 9 05-08-2008 08:23 AM
