Just got back from a trip to the Upper Peninsula. It was a 13 + hour drive from Illinois to Michigan and when I arrived at the campground I discovered that my
Scamp battery was dead. The fuse for the truck/trailer charging circuit was bad and since the
refrigerator draws 10.5 amps it was not surprising that the
battery was discharged. Hooked up to shore power, replaced the fuse and wondered how long it would take the Progressive Dynamic PD9130 converter/charger to charge my Scamp’s
battery. After going on the PD website I discovered that the PD9160 converter (60 amps vs 30 amps for 9130) takes 70 hours at 13.6 volts to fully charge the battery. Not good, but PD sells a Charge Wizard #PD9105 – that has a boost mode (14.4 v) that will charge a battery to 90% full charge in 2-3 hours. I bought one, $28 on Amazon, installed it and it works as advertised. Check out their website, lot of good info. Terry
