Pros/Cons Running Solar Cable Outside Trailer - Fiberglass RV
Old 07-24-2014, 08:04 PM   #1
Trailer: ParkLiner
Virginia
My plan was to have the solar panel cables come through the roof to connect to the charge controller, then exit through the floor with battery cables to connect to battery.
So I'm thinking why not just run the solar cables down the front of the trailer, mount a box for the charge controller somewhere close to the battery, and then have just 3' of cable to the battery. I plan on having 2 y cables that will allow me to connect a portable solar panel if I choose to. I could locate the y cables in the box so they would be easily accessible.
Outside of appearance, is there any reason not to run the cables outside?
Any ideas on how to make it look pretty? If the cables were white, I might not even worry about it.
Huck is offline   Reply With Quote
Old 07-24-2014, 09:06 PM   #2
The Minimalist's Avatar
Louisiana
I did in that way for a couple of years. It works, but you're right. It ain't pretty. I'm in the process of rewiring as soon as I finish building my amp/volt monitor.
Clif
Old 07-24-2014, 09:50 PM   #3
Borrego Dave's Avatar
Huck, wire it up like you are thinking, white sounds good. See how it all works for you cuz you can always change it later like Clif is doing. After a year or so the tech will change and you'll be thinking of another setup I'm betting . The mods never end.......
Old 07-24-2014, 10:13 PM   #4
tractors1's Avatar
Trailer: Escape 21 - Felicity
Easiest route down from the roof is usually down the reefer vent.
Charlie Y
Charlie Y
Old 07-25-2014, 03:38 AM   #5
deryk's Avatar
New Jersey
Charlie Y
Great Idea, but ParkLiner doesn't have a vent on the roof for the fridge. Possibly could snake it down the vent for the water tank... but would be a longer cable run. I ran mine through the roof in the front bathroom...so if it ever did leak through the marine cable fitting it would drip into the shower.
deryk
Old 07-25-2014, 09:57 PM   #6
MCDenny's Avatar
Trailer: Lil Snoozy
Lowes sells a flat plastic conduit for routing computer wires. Two 10ga wires fit inside. Looks better than the naked wire.
Denny Wolfe
Wanderingourway.wordpress.com
MCDenny is offline   Reply With Quote
Old 07-26-2014, 07:05 AM   #7
Timber Wolf's Avatar
North Florida
I like deyrk's plan of coming down in the shower, it is in the right spot in my Scamp anyway. I also wonder about running a 1/2" white pvc water pipe down the front of the trailer. Not ideal but prettier than bare wires and certainly provides the wires adequte protection. Don't know how to mount the pipe though.
Old 07-26-2014, 08:08 AM   #8
Trailer: ParkLiner
Virginia
I've been staring and measuring for the last couple of days. I think on the Parkliner, you almost have to go through the shower unless you run the cables through the vent.
Looking at the picture, you can see that to get to either side, you have to run the cables up over the ridge. And it's not high enough to run the cables through it sideways using a waterproof mount. I guess you could use grommets and drill a couple of holes and seal real good. Since it's on a vertical surface, it probably wouldn't leak as easily as the flat areas.
The flat area in front of the panel is the area over the shower.
Old 07-26-2014, 09:58 AM   #9
Mike Magee's Avatar
Trailer: 93 Burro 17 ft
I would keep the wires outside. The short run from controller to battery is advantageous in minimizing power losses anyway.
Personally, I kept my panel portable and set it on the ground when camping. Easy as it gets.
Old 07-26-2014, 11:18 AM   #10
Louisiana
Denny Wolfe
I would be concerned about UV deterioration.
Clif
Old 07-26-2014, 11:22 AM   #11
deryk's Avatar
New Jersey
The fitting I used on mine going through my roof was designed for fiberglass boats so I'm pretty confident it will keep the water out.
http://www.fiberglassrv.com/forums/f...lar-64512.html
deryk
Old 07-26-2014, 11:41 AM   #12
Trailer: ParkLiner
Virginia
I was saying that if I wanted to go in through the closet instead of the bathroom, I would have to either go through the vertical piece or run the cable up to the higher part of the roof. If I went through the vertical, I don't think there is enough room for the type fitting you used. That's why I was saying maybe grommets and then sealing.
solar
Pros and cons of a very small 3-way refer rabbit Modifications, Alterations and Updates 21 03-19-2012 12:03 PM
Pros and Cons Alan Ursacki General Chat 11 10-01-2011 05:18 PM
Atwood Everest Star 7912 Furance = pros and cons Kurt in BC Modifications, Alterations and Updates 10 02-18-2008 12:05 AM
Pros and Cons of fiberglass and Casitas Paris Winchell Care and Feeding of Molded Fiberglass Trailers 3 08-02-2007 12:33 PM
Pros and Cons of different types of windows Peggy Problem Solving | Owners Helping Owners 2 06-15-2007 05:25 AM
