Question about Boler power converter - Fiberglass RV
Old 04-21-2013, 01:59 PM   #1
Trailer: 1978 Boler 13'
This may be a very dumb question, but I know beans about anything electrical and wanting to make sure I don't accidentally zap myself. I'm removing the bench from our Boler to which the power converter is attached, and needing to disassemble the wiring to the converter to do so.
Here's my question:
Does the power converter retain any kind of charge that I need to be concerned about? It hasn't been attached to any kind of power for a few weeks, but I believe that with some kinds of electrical transformers, they retain a charge for some time after they've been plugged in, not sure if this is in any way similar, (like I said I don't know beans about electrical), but just wanted to make sure that in messing with the converter I'm not going to electrocute myself.
desy is offline   Reply With Quote
Old 04-21-2013, 02:03 PM   #2
Thomas G.'s Avatar
Trailer: For Sale Or Rent
Rooms to Let 50 Cents
You are thinking of capacitors. None there, just watch out for the battery and associated wires.
Old 04-21-2013, 02:49 PM   #3
Brian B-P's Avatar
Hmm... my converter does have a capacitor to smooth the DC output. After the AC power is off and battery is disconnected, just turn on a light for a moment to discharge that capacitor (in case there is one), and there's no problem.
Yes, any wires between the battery and converter will still be powered by the battery even though the converter is turned off. I would disconnect the positive cable at the battery before doing this sort of work to avoid unpleasant surprises.
Old 04-21-2013, 05:52 PM   #4
Raz
Raz's Avatar
Vermont
Older converters are more likely to have high value electrolytic capacitors. They bite . The newer switching converters have lowpass filters which are less likely to store much energy. Follow Brian's advice, you'll be fine
Old 04-21-2013, 11:11 PM   #5
Thanks
Thanks to all who responded, I'll give that advice a try to be sure.
Old 04-22-2013, 04:53 AM   #6
Yes becareful, you don't want any of that valuable smoke to escape through your ears!
Be safe.
boler
For Sale: Original Boler Power Converter? Luis Parts: Buy | Sell | Trade 1 02-20-2013 05:58 PM
Anyone try this power converter DannyH Problem Solving | Owners Helping Owners 13 12-04-2009 12:56 PM
Power Converter Chester Taje Problem Solving | Owners Helping Owners 14 08-10-2007 10:24 AM
Power Converter gerry gregory Problem Solving | Owners Helping Owners 7 08-31-2006 11:18 PM
Power Converter Legacy Posts Problem Solving | Owners Helping Owners 3 05-25-2003 07:02 PM
