Originally Posted by David Tilston
I agree with your reasoning.
Originally Posted by Byron Kinnaman
Yes it will work as long as you connect positive to positive and negative to negative. Now for yabut. It is recommended though not necessary that connection from a multiple battery system be made cross battery. That is negative one one of batteries in the case of two batteries and positive on the other battery. This would be true for both charging and powering the trailer. The reason is that if becomes much more obvious if the connection between the batteries fail. Otherwise it doesn't matter.
Thanks. In the pictures I have found, they were usually connected cross battery, but I didn't think it had to be that way. Byron, your explanation makes perfect sense. If I can go cross battery, I will, but my cables may not be quite long enough.
