re hard wiring a 300 watt inverter to my motorhome - Fiberglass RV
Old 09-12-2013, 07:42 AM   #1
Trailer: lunar
isle of wight
Hi all. I am a new member and I am looking for help with wiring in my 300 watt inverter to my motorhome.
Can anyone tell me how I need to wire it in to the main engine system and charging system.
I can do some electrics but need help with this.
Look forward for your help.
Thanks John
John Goodwin 200 is offline   Reply With Quote
Old 09-12-2013, 07:50 AM   #2
cpaharley2008's Avatar
Welcome to FGRV John,
We are a forum of molded fiberglass trailers, no motor homes. Although we may share similar modifications, you may be better posting in another forum. Good luck with your search, let's hope you may get some responses here or elsewhere.
Jim
Never in doubt, often wrong
Old 09-12-2013, 09:32 AM   #3
David Tilston's Avatar
I will take a stab at it.
I would wire in a separate auxiliary battery. It would be in parallel with your vehicle battery, except, I would wire in a battery solenoid that closes when your engine is running. This way, you have some power after you turn off the engine, without worrying about draining the battery. The inverter, (300 watts?) would then connect to the aux. battery. I would also think about getting a bigger inverter.
Be sure to size the wire to the aux battery, and to the inverter appropriately. The battery wire should be the same size as the wire from your current battery to the alternator. At 300W, your inverter should not be drawing much more then 25A.
I suppose you could skip the second battery, and just use the solenoid.
Old 09-12-2013, 09:55 AM   #4
As with all things electrical and propane I strongly recommend that if have to ask take it to somebody that knows. If a business screws up they're liable, if you screw up you're liable. The loss of a motor home or trailer just isn't worth the risk.
Old 09-12-2013, 10:33 AM   #5
Brian B-P's Avatar
What David refers to as an auxiliary battery is also known as the coach battery in motorhomes... and yes, what he describes is standard good practice. The vehicle battery is sized and specified to suit engine starting requirements and other vehicle systems; the coach battery is sized and specified for RV needs. For instance, my Ford gas chassis motorhome has a typical 12V vehicle starting battery like any gas Ford truck, and the coach has a much larger set of two 6V deep-cycle batteries.
The motorhome's coach battery is just like a trailer's battery: it is connected to the vehicle charging system by a suitable isolation device, it normally gets charge by a shore-powered charger as well, it supports all coach loads such as an inverter to run appliances, and it is of a different size and type from the motor vehicle battery.
Motorhomes often have one feature not found on trailers: a switch can be used by the driver to temporarily connect the coach battery to the vehicle battery to assist with starting in an emergency (such the vehicle battery having run down due to problems starting, or leaked down over a long period of not being used). This would generally not be appropriate for a trailer because the wiring between tug and trailer is not heavy enough, but the corresponding connection in motorhomes can be thick cable.
Old 09-12-2013, 11:42 PM   #6
Brian Van Snell's Avatar
Trailer: Escape 13 ft 2010 ('Ladybug') / 2003 Subaru Forester
I installed a 300 watt inverter in our trailer, and installation was quite straight forward. The manual that came with your inverter should provide some guidance. Here is a link to the manual for our inverter: http://gpelectric.com/files/gpelectr...300_vF-WEB.pdf. In the UK you will need a 50 cycle 230 volt equivalent.
Is your motorhome similar to this? http://www.lunarcaravans.com/brands/...er-car/vacanza
Some things to notice:
  1. The inverter should be located close to the battery you use for lights and appliances. It is possible you have only one battery in your motorhome. It is recommended to reduce the risk of explosion that the inverter not be in the same compartment as the battery.
  2. You need to use heavy cables between the inverter and battery. Our inverter came with 4 foot #10 AWG stranded wire (#12 SWG)
  3. Insert an adequate fuse between the battery and the inverter
  4. Make sure to ground the inverter. Our inverter recommended #8 AWG (#10 SWG) stranded wire.
  5. Don't connect the output from the inverter to the alternating current (AC)(mains) distribution system[/B] -- use a separate outlet for the AC power from the inverter or just use the outlet on the inverter itself.
  6. An alternative is to use a transfer switch, but this is more complex -- you had better read up on this if you want to go this route
  7. Good idea to have a remote on/off switch for the inverter as it will consume power even when there is no AC load. Alternatively turn the unit off when you are not using it.
  8. If you have sensitive AC appliances consider a true sine wave inverter
You can find more information on our installation here: http://www.escapeforum.org/forums/f8...ar-2057-2.html
Brian & Maria
2010 Escape 13 "Ladybug"|2003 Subaru Forester|2012 Toyota Highlander
Brian Van Snell is offline   Reply With Quote
Old 09-13-2013, 05:29 AM   #7
Hi John, I suggest you asked your question at a forum dedicated to your motorhome type: iRV2 Forum | - RV Forum Community and RV News which is owned by the same group that owns FiberglassRV. You'll find equally kind and helpful people there.
Best of luck
1500 watt pure sine wave inverter BAMA & Pachyderm Posse Electrical | Charging, Systems, Solar and Generators 9 06-10-2013 01:07 PM
inverter wiring Dick & Joanne Modifications, Alterations and Updates 10 01-27-2013 12:41 PM
New 2000 Watt Inverter Generator Ray N Care and Feeding of Molded Fiberglass Trailers 16 12-02-2010 09:31 AM
Hard-Wired Inverter peterh Modifications, Alterations and Updates 25 03-11-2009 09:40 AM
Vector® 750 - watt Portable Power Inverter Kevin K Classified Archives 0 04-25-2008 10:55 AM
