Remove Refrigerator - Fiberglass RV
Old 08-29-2014, 09:59 AM   #1
Trailer: Burro
New Mexico
Remove Refrigerator
Does anyone know how to remove a refrigerator from the Burro? I have a 1983 Burro with a Dometic 201 fridge that I want to remove. It's EXTREMELY heavy and it looks like it's lost its refrigerant and it's all rusted on the bottom. I removed the set screws from around the flanges but I can't pull it out. Is it attached from the bottom somehow? If so, how do I access those attachment points to remove this son of a gun? I just bought one of those new koolest Coolers that are due to be released in Feb 2015 and I'm going to replace this fridge with the kooler.
Any idea?
John Colangelo is offline   Reply With Quote
Old 08-29-2014, 10:01 AM   #2
David Tilston's Avatar
You will have to open the bottom exterior vent. Propane, 12VDC, and 120VAC will have to be disconnected before it will pull out. There may also be some more screws holding it down.
Old 08-29-2014, 10:38 AM   #3
Trailer: 2010 13' Scamp
Over on Scampers group, there's been some discussion about not being able to get fridges out through the Scamp door! Some say it was put in through the back window w/o the frame; some say remove the fridge door; some say you have to take the back cooling coils loose; some say to trim the wood (screen door frame) around the door...yada yada... Yikes!
If mine ever quits, I want to replace it with the small Wally-World "compressor" types. I dont boondock and if I do it's with a gen. I would miss the on-road 12v capability of my current 1.9 Dometic though. It works wonderfully with NO issues on running the battery down...even if left plugged in while stopping to eat. You just need to remember to switch it over to ac or propane when you're camping.
Darral
Darral is offline   Reply With Quote
Old 08-29-2014, 01:57 PM   #4
In addition to the above, there may be caulking around the front to seal the living area of your trailer from a possible propane leak. Use a putty knife to check. It's best to have someone outside pushing and someone pulling from inside.
Old 08-30-2014, 07:36 AM   #5
Trailer: Burro
New Mexico
Removing the Refrigerator from a Burro
Many thanks to everyone who responded. I did disconnect the LP and the 112V and 110V connections and with a few mighty HEAVE HOS, I was able to extricate the refrigerator. The bottom was all rusted out and boy was it HEAVY! No need to be pulling all of that weight down the road for a very little value proposition in return. Instead, I've purchased one of those COOLEST COOLERS that will be out in Feb 2015. It has a built in Bluetooth speaker, a USB port. a built in 12V battery to power LED lights and a blender! It also provides more room than the refrigerator for keeping food cold. I think repacking a cooler with ice every day is easier than messing with the refrigerator. One less device to worry about. Plus, I discarded a lot of unnecessary weight. When I finish my restore I'll post pictures! This group is great!!!! Many thanks to all of you, this is a great example of collaboration.
Old 08-30-2014, 10:03 AM   #6
FTTRV's Avatar
Trailer: tp
I removed a fridge from a Bigfoot 5th wheel years back. Had to remove the door and the controls on the bottom of the fridge. The fridge then was had 1/2 inch on each side of the door to remove. The new fridge was narrower and went in without problems.
Chuck
Old 09-01-2014, 07:03 AM   #7
Trailer: Burro
New Mexico
Thanks Again!
This forum is so incredibly helpful. It's an extension to my toolkit to have all of these people with so much experience contributing to my restoration project! How cool is this. I just wanted to take a moment to thank the entire community for excellent collaboration and cooperation.
BTW- I saw an egg design that I really like. The seam is in the middle of the vehicle with a ridged cap system that lets water flow over the seam. What a brilliant idea to put the seam there instead of the roof where it's largely inaccessible.
Does anyone have any tips on servicing the roof of your RV? For starters, how do you get up there since you can't put any weight on the top of the Burro?
Everyone enjoy Labor Day Weekend 2014.
Stay healthy, happy, and think positive thoughts!
John
refrigerator
To remove or just paint ensolite ursulap Problem Solving | Owners Helping Owners 11 07-04-2009 05:43 PM
How do you remove an awning on a Bigfoot ROIDON L Problem Solving | Owners Helping Owners 3 06-29-2009 07:51 AM
How to remove drum trap on sink? Kevin Dyck Problem Solving | Owners Helping Owners 3 06-25-2009 10:03 PM
Do you really use your sink or stove? Should we remove? Stacy Crotser Care and Feeding of Molded Fiberglass Trailers 27 06-06-2009 09:54 PM
to remove decals or not to remove johnsoba General Chat 15 06-08-2006 12:10 AM
