Replace converter for 1972 TrailMite - Fiberglass RV
Old 01-17-2018, 07:40 PM   #1
Trailer: trail mite
Hello,
My 1972 TrailMite (scamp like) needs a new power source so I can plug in and have a battery back up. The original had 15 amps. Any ideas out there?
thanks!
Julie
jbenkovich is offline   Reply With Quote
Old 01-17-2018, 08:09 PM   #2
John in Santa Cruz's Avatar
Mid Left Coast
what did this trailer have? was there an old converter that died, and you want to replace/upgrade it ? I'm afraid I don't know anything about Trailmite, nor what sort of power converters were used circa 1972...
I'd likely be looking at a wfco or pd4600, maybe 30-45 amps, assuming you have a group 27 or 29 sized marine/rv battery. theese come either as just a converter that you slide into an existing power center (assuming you have one thats apprporiately sized), or they come as a complete power center, to which you'd wire your AC supply cord, all your AC sockets and circuits, and your battery and all your DC circuits.
example:
https://www.progressivedyn.com/rv/po...charge-wizard/
I do note most all of these are designed for a 30A AC input circuit. I also note that both of my 30A trailers work just fine on a 15A extension cord in the driveway at home as long as I'm not using air conditioning.
Old 01-18-2018, 08:57 PM   #3
Trailer: trail mite
Converter or Not
Thanks John for your response, I appreciate your time.
I'm thinking maybe I don't need a converter at all... The battery will only light those little dome lights. An LED lantern and the likes might be all I need?...
I need to concentrate on replacing the propane stove and furnace.
Old 01-19-2018, 12:48 AM   #4
Mid Left Coast
a furnace will have an electric fan, which draws a fair bit of power when its on.
without a converter, you would only have tow vehicle charging, unless you bring a separate battery charger and connect it when you need it, or have solar charging...
Replace "American" converter? beardrum Care and Feeding of Molded Fiberglass Trailers 23 08-31-2013 05:52 AM
To Replace Or To Not Replace??? Susan Landis Modifications, Alterations and Updates 11 07-29-2011 09:19 AM
Removing 1982 Burro from trailer to replace floor Legacy Posts Problem Solving | Owners Helping Owners 15 07-10-2008 09:10 PM
Do I Replace converter or Not? Chris and Ame Care and Feeding of Molded Fiberglass Trailers 14 07-27-2007 08:13 PM
'72 Trailmite For Sale Glendale, CA Erik B Classified Archives 0 05-31-2007 10:59 AM
