Originally Posted by Byron Kinnaman
.....Example above 8.3 amps at 120 volts = 83 amps at 12 volts. (Note to Jim, drop the hours that's, in the case of trailers, for batteries).......
Good info on that conversion.
Considering an 85 watt
solar panel might be 5 amps and... well that won't work. Always going to be running off of
battery, drawing more than
solar can provide.
Real question then is how long will it take to drain the amp hours off the batteries at the AC amp draw with the
solar amperage input.
Just a ballpark but... one 85 watt panel at 5 amp might be 30 ah a day (using charge at 100% for 4 hrs, 50% for 4 hrs) so three panels would "add" enough to run AC for approx one hour. Running into negative for daily power after that. Dual 200 ah batteries give you approx another 2 hrs of power for AC before batteries hit 50% charge. But it would take 2 days of no AC to replace that
battery power from solar.
So if you had good sun and about 48" x 65" of solar panels.... Sounds like the fan is the waaay better option. There are parts of the country where not having AC would probably be a pretty poor option. But need shore power or gennie to run it. Or go during cooler season. Only reason to go to Fla in summer is to time how long it takes CD collection to melt without AC.
