Running furnace off battery power - Fiberglass RV
Old 09-25-2017, 10:49 AM   #1
Iowa
Hi all,
Will be taking off on a mostly boondocking trip in mid-October. Given the time of year, we are expecting chilly nights, which brings me to my question:
How much usage can I expect from running the furnace when needed solely on battery power? I have a Scamp 19 foot fifth wheel with one group 24 battery and will likely set the furnace at about 50 degrees or so. I will also be using a Mr. Buddy to warm up the interior before turning in for the night.
Thanks all. Any input would be greatly appreciated.
Peter S. in Iowa is offline   Reply With Quote
Old 09-25-2017, 11:03 AM   #2
Byron Kinnaman's Avatar
Originally Posted by Peter S. in Iowa View Post
Hi all,
AHHHH The furnace heats from propane only the fan used battery. Depending on how cold it is and how much the furnace runs determines how much propane it uses and how much battery it uses. Manual says 3.5 amps. My measurements say 3.0 to 3.1 amps. With the 19ft it will probably take more battery and propane than my 13'.
Old 09-25-2017, 11:05 AM   #3
floyd's Avatar
If the outside temperature is not too cold (high 30's to mid 40's) and you set your thermostat low, you will not use a lot of battery overnight.
These furnaces are battery hogs and scamp windows cascade a lot of cold air.
Go to Menards (or equivalent) and buy a roll of reflextix. Cut window covers from the reflextix and use them at night. They will save on battery and propane and keep your trailer more comfortable in cool temps.
Too many variables to be more exact, but it may be good to have your Buddy Heater with you as a spare. One pound cylinder should last all night with the windows covered.
Like a cooler works for ice, the window covers will help for holding heat in.
The more you keep the less you have to make.
Old 09-25-2017, 11:38 AM   #4
I guess you can call the furnace a battery hog since it uses more battery power than anything else in your trailer. However at Manual current of 3.5amps that would be about 10 hours of running. Hmmm. Even in 5°F weather I don't think mine ran for more that 2 hours a day. That would mean 7 amp hours per day 37/7 which results in a little over 5 days without recharging. Yes the furnace draws more than some things do but not all that much.
Old 09-25-2017, 12:17 PM   #5
floyd's Avatar
Unless you meant 5 degrees Centigrade I think your two hours a day (5 minutes per hour) is pretty incredible!
At 5 degrees Faherheit the windows let in more cold than a reffer unit on a Monfort truck! At any rate covering the windows helps a lot!
BTW... I wish I had one of those "degree" symbols on my keyboard!
If it IS there I don't how to find it.
Old 09-25-2017, 01:44 PM   #6
ZachO's Avatar
Trailer: Sasquatch
Montana
My mostly unscientific advice, based on my trailer (different than yours) in October-like temps (pretty wide range) and chilly nights (pretty subjective), my personal use (different for everyone), and using my trailers monitoring center to tell me the state of my battery (pretty darn un-exact), I say that you have two full nights, three days of use on a good battery before you're drawing it down to dangerous levels.
This is using a little heat at night before bed, heat set as low as it will go overnight, then heat for the first couple hours of the morning, but none during the day. And just some LED lights, a little water pump use and that's it. If your lights are incandescent, and you're hanging out for a couple hours at night and in the morning using them...then way, way less battery life than my prediction.
But I can get a solid two nights out of my battery using the furnace without a recharge, before my battery monitor starts scaring me.
Old 09-25-2017, 01:59 PM   #7
I think I said 5°F F=Fahrenheit
A bit of explanation. At night the thermostat was set a 45° to 50°F, During the day it was set at 65°F. And it never ran more 2 minutes at a time. As a side note your body heat will keep the trailer above freezing.
I don't know if you've ever been in a snow cave, but I can tell you the inside temperature is around 40°F with ice all around you.
Old 09-25-2017, 02:00 PM   #8
NW Wisconsin
We turn up our furnace for a few minutes before going to bed , then set our Tstat to the lowest setting , jump under the covers and go to sleep .
When we get up in the morning we turn the Tstat up for a few minutes to take the chill off
We have been able to go 3 days without charging our single 27F battery.
As long as we can't see my breath at night it's plenty warm for us.
Old 09-25-2017, 02:17 PM   #9
Trailer: 2013 casita pd
this is a difficult question to answer because of the many variables involved. how cold will it get, what temp will you set your furnace to, how much area does it need to heat, are your windows covered to retain heat? i like it warm, so i run my suburban furnace set at around 68 throughout the night in my 13ft casita PD. i don't cover my windows. when it is particularly cold outside, it can draw my battery down to half in a couple of nights. when outside temps are warmer, i can get maybe 3 nights. your results will vary.......
clairemr1 is offline   Reply With Quote
Old 09-25-2017, 03:36 PM   #10
floyd's Avatar
Pretty much DITTO for us with our 13!
Old 09-25-2017, 05:33 PM   #11
Trailer: Boler 13 ft
in my Boler 13, if my battery is 100% to start I could boondock for 2 days and nights on Battery power. This was with the heat off during the day.
Furnace has to have power to run the fan and open the gas valve. Many a night I would wake to hear the fan running but I was cold because there wasn't enough power to open the gas valve and spark the electronic ignition while the fan was on.
Old 09-25-2017, 07:23 PM   #12
tractors1's Avatar
Trailer: Escape 21 - Felicity
Yup, I winter camped for skiing and got irritated enough to rip the furnace out and put it on a test bench with a variable power supply to figure just how low I could go. Bottom line is the gas valve stopped working at 10.7 volts. Added a 2nd battery so I could spend the whole weekend camped at ski resorts (really really cold at night on top of a mountain.)
Charlie Y
Old 09-26-2017, 09:55 AM   #13
Trailer: Scamp 13
In our Scamp 13 with Attwood II furnace I could get 3 nights until the fan wouldn't have enough speed to open the gas valve. We camp in the desert in January for 5 days or so. high 20'sF at night and starts getting cold as sundown approaches. As the darkness approaches the heater goes on and thermostat is set about 68 degrees f and runs through out the night. Roof vent is cracked a bit to let out moisture. It comes on between 4 to 8 times through out the night depending on how cold it really gets. while we are sleeping. I put out my portable solar panels (60 watts total) to recharge the battery by day. When we return to the trailer at dusk the battery is fully charged. Do to our location I have to hang my solar panels off the side of the trailer to collect the low winter sun. Even with the low winter sun my battery is fully charged every day. At night my battery is 12.7 volts and in the morning it is 12.4 or 12.5 when using the heater. I have 1 group 27 walmart battery and all lighting is L.E.D. and I run my DVD player for 2 to 3 hours or more each night. I use foil bubble pack over my windows to cut the draft from the glass.
Heating up a 19 footer has to be twice the area of my 13 footer. Maybe placing the heater in an appropriate spot and utilizing a curtain you could reduce heating to the sleeping area while you are in bed. Just like the old days you don't heat the whole castle just the areas you are actually in. If you had enough battery and recharging capability a 12 volt blanket might work and give you peace and quiet at night.
Old 09-26-2017, 10:07 AM   #14
Trailer: Escape 19 ft 2010
If it is a windows computer hold down the Alt key and type 248 using the numeric keypad. There is an equivalent command on Macs.
Paul Braun is offline   Reply With Quote
Old 09-26-2017, 11:23 AM   #15
Correct.
Old 09-26-2017, 12:44 PM   #16
TomK's Avatar
Trailer: Scamp 16
On a Mac, you hold option (alt) key and type 0 (zero) º
I always wanted to do that too. Learn something every day! ºººº Woo Hoo!
Tom
TomK is offline   Reply With Quote
Old 09-26-2017, 01:14 PM   #17
Jon Vermilye's Avatar
Trailer: Escape 17 ft Plan B
Tom
option 0 = º
option/shift 8... °
They are different - not sure which is "Official".
Old 09-26-2017, 05:37 PM   #18
[QUOTE=stevebaz;663369]In our Scamp 13 with Attwood II furnace I could get 3 nights until the fan wouldn't have enough speed to open the gas valve. We camp in the desert in January for 5 days or so. high 20'sF at night and starts getting cold as sundown approaches. As the darkness approaches the heater goes on and thermostat is set about 68 degrees f and runs through out the night. Roof vent is cracked a bit to let out moisture. It comes on between 4 to 8 times through out the night depending on how cold it really gets. while we are sleeping. I put out my portable solar panels (60 watts total) to recharge the battery by day. When we return to the trailer at dusk the battery is fully charged. Do to our location I have to hang my solar panels off the side of the trailer to collect the low winter sun. Even with the low winter sun my battery is fully charged every day. At night my battery is 12.7 volts and in the morning it is 12.4 or 12.5 when using the heater. I have 1 group 27 walmart battery and all lighting is L.E.D. and I run my DVD player for 2 to 3 hours or more each night. I use foil bubble pack over my windows to cut the draft from the glass.
Wow only 4 or 8 time a night will the furnace come on.?.
When winter camping in the White Mountains of NH and the temps down to the single digits my furnace will turn on about once every 2 minutes threw-out the night.
I have a 79 Boler 13 so it doesn't take long to heat up but it sure does cool down fast too.
Even after insulation was put on floor 2 nights was max.
The fan does tell the gas valve to turn on but it takes power also to turn gas valve on.
With a week battery I will hear fan run... then when gas valve tries to turn on, the fan will slow down but still run.
Old 09-26-2017, 06:08 PM   #19
Obviously, how high you set the thermostat will have a huge effect on battery life on cold nights. When I stayed in Quartzsite last winter I didn't have a concern about battery life since I had 395 watts of solar & a pair of 6V, 232 amp hour batteries. I did want to conserve propane to avoid trips to refill the tanks.
I set the thermostat at 57°F, which I found quite comfortable for sleeping under a blanket. Many nights the furnace never came on, but when it did, it ran for a fairly short time (I did have the extra insulation package which includes dual pane windows in my Escape 17). During the middle of winter I was going through a 20 pound tank of propane every 10 - 14 days.
Setting the thermostat at what some would feel a necessary 70°F would probably cut that in half, and without solar, put quite a load on a single battery.
Old 09-26-2017, 07:31 PM   #20
floyd's Avatar
Wow ! I now have a ° .
Now to what ° I am able to remember it ....
It was 92°F here todayHope it cools off tonight (Maybe 65° or 68°)
While experimenting I found all kinds of stuff...
battery, furnace, scamp
Furnace running even with thermostat off allan3089 Problem Solving | Owners Helping Owners 12 02-19-2017 09:32 PM
Power draw from tv battery when turned off Wallo Towing, Hitching, Axles and Running Gear 39 06-08-2013 11:36 AM
Troubles running off battery alone. byAndrewDavis Problem Solving | Owners Helping Owners 14 04-01-2011 09:08 AM
Charging Battery and running battery lights when plugged in Nor_Cal_Todd Problem Solving | Owners Helping Owners 2 08-25-2010 01:44 PM
Battery power for an Atwood Furnace Mac B Problem Solving | Owners Helping Owners 29 12-03-2009 01:00 AM
