Running Lights Not Working on an 82 Scamp - Fiberglass RV
Old 07-09-2015, 01:33 PM   #1
Well. I'm nearing the point where I take her in for some help although I don't want to give up and think I'm pretty close to figuring it out.
Here is my scenario. All of running/brake/blinker lights were working. Then they all went out at the same time. I got a circuit tester and was able to determine that there is power getting to the fixtures. I didn't think it was the bulbs but tried that out. No luck. I then figured I'd try to take a wire from the ground connection off the battery and trailer harness to the fixture directly. Once I touched the ground wire to the ground on the fixture it turned on. Each fixture has it's own ground running to the chassis of the trailer. I even took the ground wire and connected it to where the fixture ground wire meets the chassis. It turned on there as well. I must be doing something wrong here but it seems like the chassis isn't grounded but that doesn't make sense. I'm getting desperate at this point!
Thanks in advance for any help.
DenverScamp is offline   Reply With Quote
Old 07-09-2015, 02:24 PM   #2
sarahspins's Avatar
Trailer: 1984 13' Scamp named "Ramblin Rose"
This likely is the problem - have you checked the connections of these wires (if the screws are rusted, they are likely NOT making good contact) or the contact point (to the frame) of the trailer harness ground?
sarahspins is offline   Reply With Quote
Old 07-09-2015, 02:32 PM   #3
Thanks, Sarah. After a little more trial and error I'm even more confused although I have a work around. Those connections seem fine and the fact that all of them went out at the same time have me thinking they didn't all corrode at the same time. Anyway, I took the ground from the trailer connection off the car and connected it directly to the trailer. At that point, the lights all worked??!!?! Is it possible the trailer isn't grounded somehow? Seems real odd.
Old 07-09-2015, 02:47 PM   #4
Trailer: 2013Escape 21
Iowa
Colleen, yes it's possible you've lost your trailer ground. Any wire to body ground can become suspect over time through corrosion that you cannot visually detect without actually removing the screw or clip or whatever holds the ground wire in place. Even if it looks ok, a little sanding with some emery cloth can sometimes do the trick. My brother in law was a mechanical and electrical wizard. His straightforward logic and methodical approach especially in camper wiring situations allowed him to solve virtually any problem. Though he passed away, way too soon, he left me with this simple advice " those grounds will mess you up"'. I go back to this every time I'm baffled and work through it with emery cloth and circuit tester in hand. Good luck
Dave
Iowa Dave is offline   Reply With Quote
Old 07-09-2015, 04:46 PM   #5
The connections from the lighting fixtures to the trailer are all good because when I hook another ground (from the trailer connector) to the trailer then all the lights work. That is what I don't understand.
Old 07-09-2015, 05:51 PM   #6
Borrego Dave's Avatar
"Trailer connector", are you talking of the 7 pin at the hitch? If so it sounds like you've lost the ground in it. Open it up and check there.
Old 07-09-2015, 05:56 PM   #7
The 4 pin is what I mean by trailer connector. I know that ground is good. As an experiment, I attached that directly to the trailer and it created a ground for the fixtures. I've reconnected all of the wires and am using an additional wire connected to the ground connections, tied it to the trailer, and now all of the lights work. The grounds from each fixture must be connected to trailer frame correctly. The trailer just doesn't seem to have a proper ground until I connect the ground from the 4 pin directly to it. It just seems odd and I'd rather do it right and know the right answer instead of stumbling across a work around.
Old 07-09-2015, 06:04 PM   #8
sarahspins's Avatar
It's not odd, but it wouldn't be grounded without that.. you should have a solid connection to your frame coming from the trailer harness. Without this in place, it really doesn't matter what is going on with the rest of the grounds for the lights, if the frame itself is not grounded to the trailer wiring. That is what I was saying in my first reply
Old 07-09-2015, 06:09 PM   #9
Ha. Sorry I missed that. I was under the impression that trailer frame is naturally grounded by it's connection to the ground.....that it didn't need to be grounded......just as the car is grounded by a connection to the frame.
Old 07-09-2015, 08:57 PM   #10
Iowa
The rubber tires which are in contact with the ground are ,I believe, more of an insulator than a ground. The four pin coming off the trailer always needs a solid connection to the frame. That's the first place to look if all the lights go out at once.
Dave
Old 07-10-2015, 09:33 AM   #11
Name: Wayne & Barbara
Trailer: Parkliner
Iowa
Ground is not always Grounded
Frame grounds are famous (notorious) for unreliability.
Our 2000 Scamp 16 ft has a hard wired ground to all lamps and fixtures.
The 7 pin connector has one pin for the ground connection to the car.
Your 4 pin connector works only for tail, stop and turn signals, with the side marker lamps also connected to the tail light circuit.
If you have a battery on the trailer, it would need a 5th pin with a hot lead from your car battery (and a fuse under the hood)
If you have electric brakes, a sixth pin is needed, and backup lights a seventh.
Old 07-10-2015, 01:11 PM   #12
Bob in Mb's Avatar
Trailer: Surf-Side
Manitoba
Did the problem occur with the trailer hitch disconnected - the hitch will complete the ground cicuit i.e frame to frame ?
Bob in Mb is offline   Reply With Quote
Old 07-10-2015, 02:02 PM   #13
Keaner's Avatar
Trailer: 1973 13' Boler
Is your vehicle trailer ground tied to the frame? What I mean is, where the ground wire comes off the 4 pin adapter, is it tied to the frame of the trailer or does it just mate up with the trailer wiring harness? Make sure the ground of the harness is also connected to the frame.
Keaner is offline   Reply With Quote
Old 07-10-2015, 02:08 PM   #14
Keaner's Avatar
Take a look at this wiring diagram.
http://www.etrailer.com/faq-wiring.aspx
light, lights, scamp
trailers lights not working on Scamp krboren Problem Solving | Owners Helping Owners 14 06-01-2015 12:56 AM
12v lights not working Brian Tin Problem Solving | Owners Helping Owners 4 09-13-2010 10:42 PM
Running Lights Stay on When not Connected to Tow Vehicle ted saxton Problem Solving | Owners Helping Owners 4 06-07-2010 07:20 PM
Running lights not working DavidS Problem Solving | Owners Helping Owners 2 09-06-2009 10:15 AM
Bigfoot trailer backup lights not working MountainHome Problem Solving | Owners Helping Owners 5 04-26-2008 10:37 PM
