Scamp 13 battery/electrical issue - Fiberglass RV
Old 10-21-2012, 06:11 AM   #1
Trailer: 13 ft scamo deluxe
New Jersey
We have a 13 ft scamp. The 120 v electrical system works fine. We installed a new deep cycle rv battery to operate the furnace and lights where the is not electric in campgrounds. The lights brighten and dim at 15 sec interval anf the converter make a fairly loud "boing" sound. The furnace will not light will just the battery power. The furnace if fine under 120 volt. Is our converter bad or is something else wrong? We have disconnected our new battery until we figure out what is wrong. For the record, we rplaced the fuses and the white wire is attached to the positive terninal.
Please help us!!! Thank you. Glenn
donnaeb is offline   Reply With Quote
Old 10-21-2012, 07:11 AM   #2
Trailer: 2014 Escape 21
Virginia
Scamp 12 VDC wiring
Normal Scamp 12 VDC wiring Black is hot+ and White is Ground-. There should be a decal stating so by the battery. The black wire should have a fuse in the line and connected to the + term. If you have white connected to + I would say you battery is hooked up backwards.
Eddie
Old 10-21-2012, 07:42 AM   #3
Thomas G.'s Avatar
Trailer: For Sale Or Rent
Rooms to Let 50 Cents
Originally Posted by donnaeb View Post
...... The lights brighten and dim at 15 sec interval anf the converter make a fairly loud "boing" sound. .......
This sounds like you have a short circuit that is protected by an automatic circuit breaker that is resetting and tripping, resetting and tripping every 15 seconds. You will need to track it down.
Old 10-21-2012, 08:10 AM   #4
cpaharley2008's Avatar
Always check your wire leads to the battery with a gauge, it sounds like you may have hooked it up incorrectly. Double check the leads prior to hook up with a tester and then attach them and test again also verify volt output. Possible the battery is low.
Old 10-21-2012, 09:48 AM   #5
Raz
Raz's Avatar
Vermont
My converter is fused in case the battery is incorrectly connected. Perhaps they used a circuit breaker for that purpose here. I would swap the battery connection putting black to positive and white to negative since Eddie says that's the color coding Scamp uses. Check the inline fuse as well. Raz
p.s. welcome to the forum.
Old 10-21-2012, 10:06 AM   #6
Scamp has two inline fuses to check as well. One near the battery and one just inside the trailer at the point the wiring enters the trailer - on mine it was hidden under the rat fur on the front wall of the trailer.
Old 10-21-2012, 12:55 PM   #7
New Jersey
Thank you very much! We finally did figure that out. As Homer Simpson might say, "Doh!" Things are working fine now thank goodness.
Old 10-21-2012, 12:57 PM   #8
New Jersey
Yes we just had our wires backwards! Black is hot, white is not
Old 10-21-2012, 01:08 PM   #9
Raz
Raz's Avatar
Vermont
Battery/Electrical - Trillium 1300 '74 Mark Fitz Problem Solving | Owners Helping Owners 12 07-16-2009 06:53 PM
scamp wiring issue jmacchi Problem Solving | Owners Helping Owners 8 05-04-2009 07:52 PM
Battery Electrical Question Michael Knelsen Problem Solving | Owners Helping Owners 0 08-09-2008 12:46 PM
Battery Issue (?) Tirah Problem Solving | Owners Helping Owners 11 07-21-2006 12:08 PM
Prodigy.. electrical battery ground ? Christi V. Problem Solving | Owners Helping Owners 16 04-20-2006 10:19 PM
