Scamp 13 - Which Exterior LED's Did You Choose? - Fiberglass RV
Old 05-18-2018, 06:23 AM   #1
barryra's Avatar
Trailer: 1993 13 ft Scamp
I'm about to change out the side markers and tail lights to LEDs on my 93 13 foot Scamp.
I'm hoping some of you could post some links (Amazon etc) on which products you had good luck with.
Thanks very much!!
barryra is offline   Reply With Quote
Old 05-18-2018, 08:57 AM   #2
ststefan's Avatar
Trailer: 1979 Boler1700
Maple Ridge, B.C.
Thanks very much!!
https://www.etrailer.com/Trailer-Lig.../STL190RB.html
These are the taillights I have and used colored led bulbs with clear lenses for my clearance lights.
Old 05-18-2018, 09:53 AM   #3
John in Michigan's Avatar
Trailer: 1978 Trillium 4500
LED sidemarkers
Very happy with these LED sidemarkers. Too bad they are out of stock at Home Depot where I purchased them for about $5 each
https://www.amazon.com/Blazer-C539A-.../dp/B004L04YCK
Trillium 4500 Journal
http://www.fiberglassrv.com/forums/f...nal-81345.html
Old 05-18-2018, 11:14 AM   #4
Trailer: 2014 Escape 21
Marker lights
Scamp uses Bargman 99 marker lights. I found Bargman 99 LED lights on E- bay to match the orig. style. The LED light has the ground mounted to the mounting screw hole so you have to solder on a ground lead to a very short wire. Kind of a PIA soldering and remounting. I just replace the lenses or old bases from E trailer or Scamp and stay away from Led marker lights on Scamps. LED light only make a real difference with the tail lights. Some car wiring adapter boxes don't like led running lights. Outback's leak voltage to the trailer lights with everything turned off and you can detect a slight glow at night.
Eddie
Eddie Longest is online now   Reply With Quote
What made you choose FBRV? JustBrowsing Hi, I am.... 72 10-04-2016 08:12 AM
How do I choose?? FishBioGirl General Chat 8 10-08-2013 09:17 PM
Which small trailer would you choose? Joel3217 Towing, Hitching, Axles and Running Gear 12 05-13-2008 09:13 PM
LOL! OK, which one of you did it? Gina D. General Chat 11 03-21-2006 11:03 PM
Which small trailer would you choose? Joel3217 General Chat 0 01-01-1970 12:00 AM
