Scamp 5er electrical problem - Fiberglass RV
Old 12-11-2012, 03:35 PM   #1
Trailer: 1972 Compact Jr
Most of my new used 5er's electric doesn't want to run off shore power. I've got a 20amp line plugged in and the trailer outlets work but the lights and pumps are running off the battery. Every few days the battery charges enough to give me temporary lights. This wouldn't be a big problem except that it's supposed to go to the low 20s and I can't pump the antifreeze through the lines! I'm going to try hooking the electric up to my (running) tow but if any of you have suggestions I'd love to hear them. Thanks in advance!
CeliaL is offline   Reply With Quote
Old 12-11-2012, 04:19 PM   #2
Thomas G.'s Avatar
Trailer: For Sale Or Rent
Rooms to Let 50 Cents
Can you plug in a battery charger and attach it to the battery? It sounds like the converter is not working or has blown a fuse.
Or attach jumper cables from the tow vehicle to the trailer battery and let it run for a while to give a quick boost.
Old 12-11-2012, 04:21 PM   #3
Raz
Raz's Avatar
Vermont
Sounds like your converter is not charging the battery. To solve the immediate problem of pumping the antifreeze, I would connect my tow vehicle to run the pump. Make sure you disconnect afterwards so as not to run down the tow vehicle battery. Next, I would start by looking for a bad fuse between the converter and the battery. I think there are wiring diagrams in the document center. Raz
Great minds think like, some type faster than others
Old 12-11-2012, 05:29 PM   #4
I tried hooking up the tow - didn't get any power I have a wiring diagram; the trouble is that it shows the fuse under the front bunk. I don't have a front bunk! I've searched and can't find the darn thing... Off to buy a battery charger and jumper cables
Old 12-11-2012, 06:44 PM   #5
Found the front fuse under the stairs. All the fuses to the converter are good. Hope the charger works!
Old 12-11-2012, 07:06 PM   #6
Bill MacDermod's Avatar
Trailer: 1999 17 ft Casita Spirit Deluxe ('Inn EggsIsle')
could the battery be bad?????
Love being Inneggsile
heading sloowly up the eastcoast to our next 2 month (Aug and Sept) camp hosting gig at Camden Hills State Park in Maine
Bill MacDermod is offline   Reply With Quote
Old 12-11-2012, 07:21 PM   #7
I sure hope not! There are no stores left open to buy a new one. The charger blinks like it's working... Otherwise I'll hope my little electric heater from the Jr. will keep everything above freezing tonight.
Old 12-12-2012, 05:00 PM   #8
Francesca Knowles's Avatar
Trailer: '78 Trillium 4500
Since you're plugged in, and the 110v outlets work but the 12v appliances don't:
You don't say what year the fiver is or what model converter it has, but it may require that you manually switch the converter from "battery" to "shorepower" in order for the 12v fixtures to operate off 110v.
The fact that the 110v outlets work is a distraction- they're completely separate from the 12v system.
Francesca
Old 12-12-2012, 05:35 PM   #9
It's a '98. It is supposed to be automatic - there is no switch on the box or anywhere else I could find. The wiring diagram shows power goes to the AC, refrigerator, and wall outlets before it gets to the converter box. Those things all work. It took 24 hours to charge the battery at a 10V charge; do I need a new battery too? (It was completely dead)
Old 12-12-2012, 05:41 PM   #10
What's the converter model name and number?
Francesca
Old 12-12-2012, 05:44 PM   #11
Here's my suggestion.
First take the battery to a business that sells automobile batteries. There's should be many close by. A battery store might be best. Let them charge the battery and test it, they'll usually do this as a free service. Once you know the condition of the battery you move on from there.
Old 12-12-2012, 05:51 PM   #12
The Scamp owner's manual at this link indicates that on the 20 amp systems there are nine circuits, all of them fused. (see page 9, "electrical system")
No indication as to where those fuses might be located, but it sounds as if there are more than just the one up in the front of the trailer. Could they be inside the converter itself?
A search of the 'net of the converter name/model number might answer that question...
Francesca
Old 12-12-2012, 06:44 PM   #13
Thomas G.'s Avatar
...... It took 24 hours to charge the battery at a 10 AMPS charge; do I need a new battery too? (It was completely dead)
You might need to replace it, or not. As suggested, take it to a battery shop and have it tested.
If it has removable caps, you can do a hydrometer test on each cell, but this may be more than you want to tackle. How to Test a Battery With a Hydrometer | eHow.com
Old 12-12-2012, 06:50 PM   #14
There is a fuse immediately off the battery, one just inside the trailer under the stairs, and one on the converter. The rest are all before the lights, stove fan, etc. All the fuses are good. Every thing works now that the battery is recharged - except the pump. I think I ran it dry trying to get all the water out of the tank (the tank drain doesn't work) I have a friend who is an electrical engineer coming to look at it next week, I guess I'll just order the converter so she can install it if needed. Is there any hope for the pump?
electrical, scamp
Electrical Problem jimmied Electrical | Charging, Systems, Solar and Generators 55 11-06-2012 07:33 PM
Electrical problem jaye580 Problem Solving | Owners Helping Owners 8 07-28-2008 08:52 PM
Electrical problem - Help! scott fraser Problem Solving | Owners Helping Owners 2 08-07-2007 06:03 PM
Scamp Electrical Problem gheicher Problem Solving | Owners Helping Owners 0 06-08-2006 04:03 AM
Trillium Electrical Problem Legacy Posts Problem Solving | Owners Helping Owners 4 07-19-2003 12:44 AM
