Scamp battery discharging when stopped and still connected to tow vehicle.... - Page 3 - Fiberglass RV
Old 10-19-2015, 09:47 AM   #29
Hmmmm.... I'm wondering if you may have more of a meter problem than a battery problem.
Here's why; at 11.9 volts, which is less than 50% charge, most furnaces can't spin the fan fast enough to trip the sail safety switch. As it turns out, many can't trip the sail switch without a fairly full charge. The .4 drop is about right for one night out when you are at full charge, but starting at a 50% charge I would have expected a faster drop.
Try connecting or plugging in your voltmeter to the TV by itself and tell us what you are reading. That should be close to 14+ volts at a fast idle.
Old 10-19-2015, 09:56 AM   #30
Hmmmm.... I'm starting to wonder if you might have a meter problem more than a battery problem. Here's why:
1. 11.9 volts is about 50% of a full charge
2. Most furnaces can't spin the fan fast enough at 50% charge to trip the sail switch and the furnace does not light off.
3. The .4 volt drop for overnight with using the furnace is about right when starting with a full charge, but I would expect to see a lot more drop when starting at a 50% charge.
4. Try connecting your voltmeter to your TV alone and check that reading. It should be 14 volts or more at a fast idle.
Old 10-20-2015, 03:41 PM   #31
Trailer: Previously owned a Scamp 13'
New Hampshire
Thanks Bob, I'll look into the meter question.
Doghaus is offline   Reply With Quote
Old 10-20-2015, 04:35 PM   #32
The American Converter per my discussion with them several years ago indicated that they stopped charging at 12.2 volts.
I didn't much like that so stopped using the American Converter and purchased a Battery Minder and now when the trailer is at home the Battery Minder keeps the battery charged.
When towing the tow vehicle charges.
When in camp about every 3 to 5 day a few hours of solar seems to do the trick.
Meter accuracy is often the cause of problems. Read and understand the specifications that comes with your meter.
Old 10-27-2015, 04:23 PM   #33
IllAnnoy
I have an 11 year old American converter and it charges to a full charge.
Was that a Typo?
Old 10-27-2015, 05:07 PM   #34
Trailer: 1999 Casita 17' SD
Ohio
I have a 16 year old 6325 Parallax converter that charges to 14.4 volts. Once there it then drops back to 13.6 volts.
Joe
battery, scamp
Battery Discharging While On Shore Power jimmied Electrical | Charging, Systems, Solar and Generators 17 11-21-2012 05:43 PM
Running Lights Stay on When not Connected to Tow Vehicle ted saxton Problem Solving | Owners Helping Owners 4 06-07-2010 07:20 PM
Discharging while being towed Carl O Towing, Hitching, Axles and Running Gear 8 07-24-2009 07:52 PM
DC lights working with no battery connected???? dora D Problem Solving | Owners Helping Owners 4 10-10-2007 06:17 PM
Staying connected while on the road Legacy Posts General Chat 1 05-01-2003 04:42 PM
