Shore power without battery? - Fiberglass RV
Old 10-31-2013, 02:27 PM   #1
Trailer: 2012 Scamp 13', "Eggcentric"
Wisconsin
My new (to me) 13' Scamp has a Progressive Dynamics PD9130 power converter. I've winterized the Scamp, including removing the battery. The power converter manual says that the unit "Operates with or without a battery connected."
Are there any issues with doing that? I'd like to be able to run a 120VAC heater & light when I work on the Scamp on cold winter days, but I don't want to plug in shore power without a battery in place unless other FGRVers say it's safe.
TIA,
… Rick
hobofoto is offline   Reply With Quote
Old 10-31-2013, 02:42 PM   #2
Trailer: none
Minnesota
Just unplug or disconnect AC power to converter, your AC plugs still should work without converter, just not anything DC would work
Hambone is offline   Reply With Quote
Old 10-31-2013, 03:57 PM   #3
Steve L.'s Avatar
I'm inclined to believe the manual.
I've run my Parallax 45a converter without a battery without issue.
Old 10-31-2013, 04:14 PM   #4
Byron Kinnaman's Avatar
As stated above I've believe the manual.
You might consider keeping a heater inside all the time. I keep the inside of my Scamp at 45° to 50°F and put a Dri-Z-Air chemical dehumidifier in the sink. This keep things from freezing and the air dry so the mildew doesn't form. It's worked quite well for the past 8 years.
Old 11-01-2013, 08:33 AM   #5
fusedlight's Avatar
Trailer: 16' 1998 Scamp
Minnesota
I pull my battery out and keep a heater going at as-low-as-it-can-go. Not an issue.
fusedlight is offline   Reply With Quote
Old 11-01-2013, 08:44 AM   #6
Wisconsin
Thanks all!
Old 11-04-2013, 04:45 PM   #7
Trailer: Scamp 13
with the battery out and the manual says its ok I would at least insulate the battery cables so they cant short out.
Old 11-05-2013, 01:01 PM   #8
Wisconsin
Thanks Stevebaz - I did that when I removed the battery. Also, as an afterthought, I unplugged the converter. We're expecting snow tonight
battery
Battery Discharging While On Shore Power jimmied Electrical | Charging, Systems, Solar and Generators 17 11-21-2012 06:43 PM
Shore Power master fuse? barbflynn Problem Solving | Owners Helping Owners 4 07-25-2012 08:51 PM
76' Surfside - Does the battey charge when shore power is plugged in? dannis Problem Solving | Owners Helping Owners 2 05-26-2012 07:36 AM
A Question About Shore Power Red-Dwarf Problem Solving | Owners Helping Owners 10 03-21-2012 04:20 PM
Converter makes noise when in shore power Tezha Problem Solving | Owners Helping Owners 9 10-13-2010 02:52 PM
