Small Electrical Fire - Page 3 - Fiberglass RV
Old 04-16-2015, 02:10 PM   #29
Dennis mn's Avatar
Originally Posted by Captleemo View Post
Thomas & Betts (T& and 3M make very high quality lugs of all shapes and sizes. I would get the nylon jacketed lugs so when you use your Thomas & Betts Stakon crimping tool (Sta-Kon Crimping Tool) it wont pinch through the nylon insulation. You can then seal it up with heat shrink or wrap it with a few wraps of 3M "88" electrical tape. If you go the junction box route which makes it handy to access your connections at a later date you can mount a terminal strip (Panel Mount Terminal Blocks) and use fork lugs. Any time you make splices they should be accessable and there is nothing more accessable than a junction box.
Thanks for the info. I have thought it through, and before I make another trip, I am going to cut out the "temporary" repairs that I made, but a new cord to go to the tug, and rewire with a junction box in each of the under couch cupboards. I really have never liked the "Scotch-lock" splice fittings that Scamp uses, and plan on eliminating as many of those as I can.
1999 Scamp Fifth Wheel, pulled by a 2014 Nissan Frontier Pro4-X
Dennis mn is offline   Reply With Quote
Old 04-16-2015, 02:53 PM   #30
My experience with electrical tape in aircraft is the heat causes it to just get gummy and make a mess and slide around.
Best to use the heat shrink or at least Scotch #88.
I think that the best solution would be to install a junction box and terminal strips. A chinch barrier terminal strip would probably be good.
with terminals like this
The wire can come loose and fall off.
with these the wire will be retained by the hooks on the end.
These have to be bought for the stud size used and the bumps on the end will hold on to the screw.
Better yet is to use ring terminals, but you have to completely remoce the screw to install and some are retained in the strip.
Here is a 3M heat shrink terminal
Old 04-16-2015, 03:03 PM   #31
Why not just use closed loop terminals, that's all I ever use?
But then again I almost never shrink wrap, tape up or solder connections.... LOLOLOL
Old 04-16-2015, 03:06 PM   #32
Roger C H's Avatar
Talking Ring Tongue Terminal
Always liked the sound of that phrase.
We had sparks flying out of our electric furnace once.
Turns out the vibration from the 60 cycle electricity loosened the screws connecting the wires to the furnace. The loose connections caused the electricity to arc and thus heat up. Scary. All connections should be checked periodically.
PS: One reason aluminum wiring never took off. the difference in coefficient of expansion between copper and aluminum causes problems. Plus copper oxide is a conductor, aluminum oxide is not.
PPS: Aircraft use gold plated terminals because gold does not oxidize.
Old 04-16-2015, 06:09 PM   #33
Ring lugs, or closed loop lugs as you call them are ok but if you go that route make sure you have a holding screwdriver to get the screws started. (http://www.amazon.com/Klein-K34-Slot...ng+Screwdriver) Once you get it started you snug it up with a regular screwdriver. On redbarren55's post I would use the terminal strip he has pictured and the blue fork lugs he has pictured as it wouldn't fall off even if it came loose but unlike an airplane which could have electrical connections or mechanical connections of any kind vibrate loose from the vibrations of the engine vibration should be a non issue in your RV for your purpose unless its near some kind of electrical motor that would cause vibrations. The way it sounds thats not the case with you. Just get the connections on the terminal strip good and snug and that should be the end of it. You can check the connections at a later date if you want to make sure they are still good and snug.
Lee
Captleemo is offline   Reply With Quote
Old 04-16-2015, 06:54 PM   #34
It's really not necessary to give instructions as to how to start and tighten a screw.
Old 04-16-2015, 07:16 PM   #35
Just trying to be helpful as I have wired up many a junction box over the years and am not sure if Dennis is familiar with those terminal strips or not but if he uses the ring lugs like you suggest it would require removing each screw that he was going to put a ring lug on and they are only about a half an inch long. It can be very agrivating to get the screw started in the threads without a holding screwdriver and I am speaking from experiance. After all I thought that is what these forums were all about, helping each other out.
Lee
Old 04-16-2015, 07:20 PM   #36
Perhaps not for you, but someone else might never have even heard of a screw starter.
If you use the forked terminals with the little bumps then you don't have to take the screw out of the terminal strip and they still wont fall off and flail around, but they may arc and heat the connection up.
The terminal strips would make a nice addition and improve reliability.
Personally after I am through rebuilding my scamp I don't want to have to troubleshoot and repair it on the road.
Old 04-16-2015, 09:01 PM   #37
Dennis mn's Avatar
I'm with you on that one, I have owned this trailer for 11 years, built new interior doors and added different flooring last year. After having this issue with the electrical system, I want to improve the system so that I never have this problem again. (My wife is making noises about trading the Scamp for a new Airstream).
Old 04-17-2015, 06:22 AM   #38
My ex's son had the same desire to buy "one of those silver looking ones" until he saw the prices. Made him very happy with what they had.
Old 04-17-2015, 06:29 AM   #39
I wanted one as well, but it is a little too heavy for my VW TDI wagon. The Scamp is just right.
Big enough, but not too big.
One reason for my setup is that with high fuel prices I want high efficiency so I can go more after I retire.
Now is the time for me to get the Scamp fixed the way I want it.
One case in point is I have replaced the floors and completely fiberglasses them top and bottom with epoxy resin and 6.5 oz fabric. Then I have bonded that with epoxy to the shell and added steel bracing for better support.
I have not yet resealed the windows and with the excessive rain we have had there is a small lake in the back where the floor previously rotted out.
The fiberglass is keeping the wood completely isolated! It is a mess, but no deterioration. Perhap I need to add some drain scuppers?
Either that or take the time now to seal the windows!
Old 04-18-2015, 11:45 AM   #40
Dennis mn's Avatar
This morning, I ordered two junction boxed to rewire my scamp. I'm going to put one at each side under the front couch. The project will have to wait until I get the hitch installed in the new truck.
Old 06-14-2015, 08:38 PM   #41
Dennis mn's Avatar
I finished the rewiring today. All connections at the front of the trailer are now inside junction boxes, using 3-M ring lugs. It sure cleaned up the area. No more crimp on connectors, and wads of electrical tape.
Old 06-14-2015, 09:13 PM   #42
Nice work.... I have redone my connections up in that area and it is a crazy mess hidden away.
One thing I did not see you mention or if you did I missed it - did your trailer not have a fuse right off the battery and another inline on the hot wire right inside with all that mess of wires under the rat fur? My 92 did/does. Should/would that not have prevented the fire?
electrical
is one there I don't want to call the fire dept but i have another electrical problem lpk49 Modifications, Alterations and Updates 7 09-07-2013 06:48 PM
How small is small? How about a bicycle/motorhome hybrid? John Mc General Chat 9 11-30-2012 05:42 PM
Electrical to Propane RV Fire Donna D. General Chat 12 05-11-2011 12:43 PM
Looking for a web video of small model car towing a small model traile ronsmith100 General Chat 3 02-14-2009 07:02 PM
Fire, Fire Everywhere & No Volunteer Fire Dept Raunie Aasland General Chat 2 11-24-2006 08:05 PM
